Removing evaporator, will heat still work?
Old Aug 4, 2005 | 02:17 PM
pisetup's Avatar
Default Removing evaporator, will heat still work?
Howdy!
If I remove the evaporator, will the heat still work?
Old Aug 4, 2005 | 02:23 PM
loodood's Avatar
Default Re: Removing evaporator, will heat still work? (pisetup)
yes....i think so anyway. this is the part inside the car, under the glove compartment right? if so, i believe it's in a big plastic housing, and you have to take that apart, remove the evaporator, and duct tape it back together, and reinstall...everything should be cool (or warm). there's a writeup on it somewhere in here or ef-honda.com.
Old Aug 4, 2005 | 02:24 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
As long as the heater core is in place and flowing, the duct work is sealed
and the fan blows,it should..
Old Aug 4, 2005 | 04:13 PM
pisetup's Avatar
Cool! I'm going to remove it then.
Old Aug 4, 2005 | 06:30 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (pisetup)
if you find a non-ac car you can take the duct peice out and swap it in to your car, and it fits perfectly.
Old Aug 4, 2005 | 06:48 PM
pisetup's Avatar
My car is stuck on vent. I replaced the heater blower motor but it's still on vent. I do not have AC. All the AC related items have been removed. What controls the vent? My heater resistor is busted, that I know for a fact. I'm currently trying to borrow a resistor from a friend to see if that is the problem.
ChevelleSSLS6
Oct 30, 2008 06:23 AM
RyCeRoCkeTz
Dec 17, 2007 06:39 PM
EG9_KID
Aug 22, 2004 04:15 PM
dingusjt
Nov 13, 2003 02:10 PM
