trouble changing 3rd brake light bulb on 92 hatch?
do you have to remove the spoiler or something to change the bulb? I already broke a piece off the bulb connector by trying to reach in there under the spoiler with some needle nose pliers. I cant turn the connector to remove the bulb.
idunno if urs is the same as mine but i got a 96 hatch and for my 3rd brake light in the corners there are things u can pop out just pop them out then un screw the screws under it and the light comes out then the bulb will just pop out hope that helps
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">do you have to remove the spoiler or something to change the bulb? I already broke a piece off the bulb connector by trying to reach in there under the spoiler with some needle nose pliers. I cant turn the connector to remove the bulb. </TD></TR></TABLE>Are you talking about the high mount brake light on the rear deck or the lights on the spoiler?
Under the light, there's an access panel. It snaps off and comes down. Under that, there are two screws, phillips, I believe, that hold the lamp assembly in. Unscrew them. Lamp housing will come out and you can pull the bulb from there.
once you get those 2 screws out, it isnt exactly easy and slide right out. but keep playing with it. i had trouble with mine, and no matter what i looked at in the shop manual, was still a little difficult. just stick with it, it'll come out.
vtec2late
11
May 25, 2008 06:58 PM
xasiansupermanx
Dec 31, 2007 03:55 PM
