Suspension & Brakes Theory, alignment, spring rates....
Do you HAVE to revalve Tein's when using a spring rate other than suggested?
Old Aug 4, 2005 | 10:26 AM
BuBBa y0!'s Avatar
Default Do you HAVE to revalve Tein's when using a spring rate other than suggested?
I currenty own the Tein SS and the recommended spring rate is min/max of -/+ 2kg's. What actually suffers? Is the shock prone to damage if a spring rate MORE than recommended is used? OR is it just drivability that suffers?
I honestly do NOT care about how the ride will be, just as long as I can use different spring rates.
So, what I'm getting at is, am i able to use different spring rates without getting my shocks revalved?
PLEASE let me know!
Thanks!
Old Aug 5, 2005 | 01:01 AM
BuBBa y0!'s Avatar
Default Re: Do you HAVE to revalve Tein's when using a spring rate other than suggested? (BuBBa y0!)
Old Aug 5, 2005 | 07:47 AM
Jasper_db1's Avatar
You don't have to do anything. A shitty ride doesn't mean a better handling car.
Old Aug 5, 2005 | 08:21 AM
BuBBa y0!'s Avatar
Default Re: Do you HAVE to revalve Tein's when using a spring rate other than suggested? (Jasper_db1)
i'm not looking for a better handling car, it's for a drag race application
Old Aug 8, 2005 | 05:42 PM
BuBBa y0!'s Avatar
Old Aug 8, 2005 | 07:54 PM
azian21485's Avatar
depending on how high you go, the shocks will just be underdamped...just like any other shock that gets underdamped, the results are the same
jdmwannabe813
Suspension & Brakes
Jan 3, 2012 10:29 PM
boyong07
Suspension & Brakes
Mar 17, 2008 03:51 PM
Team Bukkake Sucks!!!
Jun 13, 2006 09:28 AM
fowler!
Feb 28, 2003 08:53 PM
.Ryan
Aug 18, 2002 04:47 PM
