AC Help
just the other day i was makin fun of my friend who has no a/c
my 91 si has a/c but it stop workin. when ever i press the a/c button the idle would drop <this is when its workin> and now i press the a/c button & no idle drop PLEASE HELP!!
has the refigerant leaked out of the system?
if you know you have a full refrig charge-->you can check the a/c comp. clutch by turning on the a/c, look at the a/c compressor, listen for the clutch solenoid to 'click'; it's very noticable; if you hear the click and the center part of the compressor pulley is not turning with the outer(belt drive) part, then the clutch or a/c switch could be bad. if no click, then check your refrigerant charge--don't convert to r134a unless absolutley necc--there are a couple of r12 replacements out there. use an a/c guage set when filling/checking the a/c system.
Modified by sam385 at 7:08 PM 8/4/2005
AZCR-V
Honda CR-V & Element
Apr 23, 2018 07:58 AM
som3on3_10
Apr 1, 2008 06:30 PM
adan CRX
Nov 26, 2003 08:41 AM
