compressing auto tensioner
Old Aug 4, 2005 | 09:54 AM
integratuner94's Avatar
Default compressing auto tensioner
hey guys im doing a t-belt swap on a 99 prelude and i need to know how or if you can get the auto tensioner compressed and keep it there without the special braket tool that Honda has.
Old Aug 4, 2005 | 10:19 AM
syntax.'s Avatar
thats one of the things that sucks about the auto tensioner, among other things. you are probably better off spending the $50+ or so on the manual tensioner and bolts while you are in there. cheap insurance and you dont need a special tool to adjust
Old Aug 4, 2005 | 10:54 AM
Default Re: compressing auto tensioner (integratuner94)
well we were hoping to get the car finished tonight...not really looking to order a manual tensioner.
Old Aug 4, 2005 | 03:52 PM
951dc5's Avatar
well i didnt need any expensive tools for that. i used zip tie to lock it tight and hold it until i put it back then cut the zip tie off. easy..
Old Aug 4, 2005 | 04:30 PM
PrettyLude's Avatar
you do know that the chances of the autotensioner failing are high due to the fact that you are reusing it.
Old Aug 4, 2005 | 08:15 PM
Honda Sport's Avatar
Default Re: compressing auto tensioner (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">well i didnt need any expensive tools for that. i used zip tie to lock it tight and hold it until i put it back then cut the zip tie off. easy.. </TD></TR></TABLE>
same thing I did...
Old Aug 5, 2005 | 03:18 AM
Default Re: compressing auto tensioner (Honda Sport)
yeah a guy at work said to do the zip tie thing too...i guess if i cant come up with the tool tonight thats what i'll use. Thanks guys!
Old Aug 5, 2005 | 03:25 AM
gaydm.accord's Avatar
unscrew, c-clamp... and either zipties or some wire. ie coat hanger maybe.
thats what i did last time. but i would reuse the auto tensioner. i did it for someone else and they wanted to reuse it
Old Aug 5, 2005 | 04:51 AM
flyrod's Avatar
Default Re: (gaydm.accord)
I have re-used several of them. I think the issue has more to do with aftermarket cams/springs. Make sure it has some oil in it when you take the plug out to turn the screw. It should move smoothly as well.
Old Aug 5, 2005 | 05:16 AM
v4lu3s's Avatar
RTFM
i do the zip tie thing as well, and have reused just about everyone that i have ever touched. i always add a little extra oil as well before I put the screw back in it, since i usually spill some oil when i open it.
Old Aug 5, 2005 | 08:57 AM
Default Re: (v4lu3s)
i'm trying the zip tie method and its just not working. it wont hold tight enough then just slips off and lets the tesioner expand. I am putting the tie on the plunger and and then around one of the mounting ears of the tensioner...and advise for this?
blu_ej
Apr 16, 2008 01:25 PM
H22Honda98
Nov 4, 2007 08:19 PM
FrostyDC4
Acura NSX
19
Dec 5, 2005 08:04 PM
BB6racer
Jun 12, 2005 01:26 PM
