Need Help my instrument panel fuse keeps blowing.
Someone please give me a hand. Every now and then the 7.5 fuse on my fuse box keeps blowing. This fuse powers my speedometer cluster lights. my instrument panel lights. For some wierd reason the fuse keeps blowing i tried replacing it with a bigger fuse and and it worked for a little while and it blew again. If someone has ever experienced this please let me know how to fix it. thank u very much.
try checking all of your wiring make sure nothing is heating up or anything unusual also make sure all your connections to everything are tight and see if that helps at all
find out what elser is on that fuse, in a power distrobution diagram that is found in the Service Manual or an ESM then play around with what all else is on the fuse, and use a circut breaker in that instence so you don't keep blowing fuses
You could have a wire that the rubber has been wore off and it is shorting out. Check your tailight and corner markers. I had the same problem in my car when I would grab second hard the fuse would blow. Because my tailight wire was exposed and hitting the metal and shorting it out. Good Luck
