jdm final drive with ? flywheel
Old Feb 20, 2002 | 01:52 PM
snake01's Avatar
Default jdm final drive with ? flywheel
I was wondering how neccesary it is to get a flywheel with a final drive gear but I want to put the gear in but I dont have a flywheel but if I get a flywheel I will need a clucth too right and if so what clucth and flywheel should I get for the R
Old Feb 20, 2002 | 01:55 PM
Cosworth's Avatar
Default Re: jdm final drive with ? flywheel (snake01)
I think the logic here is to do one installation, instead of taking it apart each time. I am going with JDM FD + Spoon or Toda flywheel + new OE clutch. I'm not making enough HP to justify getting a stiffer clutch at this point.
BABY NSX's Avatar
You have three options:
1) do the flywheel
2) do the FD
3) do them both
The choice is up to you but option 3 is the best!
Old Feb 20, 2002 | 02:01 PM
snake01's Avatar
Default Re: jdm final drive with ? flywheel (BABY NSX)
thanks guys but all I have done to the car is h/i and I want to put the final drive gear in and then the flywheel will my stock clucth hold up
Old Feb 20, 2002 | 02:04 PM
Reid's Avatar
Global Moderator
The final drive will have no effect on your clutch.
Old Feb 20, 2002 | 02:15 PM
96 SOHC VTEC's Avatar
Don't need the clutch to have the flywheel. My friend has the JDM final drive with GSR 5th gear, Comptech lightened flywheel, and an Excedy clutch. It is a very nice setup. The clutch was definitely an improvement over stock as well. Hope this helps.
snake01's Avatar
Default Re: jdm final drive with ? flywheel (Reid)
but if I put the flywheel in how bad will that be on my clucth
Old Feb 20, 2002 | 03:38 PM
Dr Pooface's Avatar
Not bad at all. Zero bad.
Old Feb 20, 2002 | 03:45 PM
lotus's Avatar
New User
Default Re: jdm final drive with ? flywheel (Dr Pooface)
Mind you my clutch is starting to feel a wee bit soft at 22,000 kms... so a clutch upgrade is a good idea while you are in there..
Old Feb 20, 2002 | 03:46 PM
1GreyTeg's Avatar
I'm doin my FD and FW next Tuesday. I currently have 17,500 miles on the Odo. I will drive the stock clutch till it wears out, then I will install another stock clutch. But, I am not doing a clutch when I do the FD and FW, since I don't need one and as someone else posted already my HP/TQ does not warrent a more HD clutch, plus I like the way the EOM/ITR clutch feels anyways.
A.
Old Feb 20, 2002 | 04:41 PM
905_S2K's Avatar
New User
AT least do the Final drive/Flywheel combo first. If you're feelin' poor then do the clutch later if your's is still in good condition. But the Final Drive and flywheel will make a noticeable difference! Go with SPOON/TODA for clutch and flywheel can't go wrong with either!
heavydman99
Jun 30, 2003 09:16 PM
Rdriven
Nov 15, 2002 12:37 PM
01 ITR 757
Oct 18, 2002 11:58 AM
Ch33se
May 27, 2002 10:38 AM
