tach, temp gauge, and fuel gauge dead
got a crx with a z6 running off a p28. comin back from a lil road trip when i noticed the tach was sitting at zero (i was doing about 60 on the highway). the temp gauge needle was all the way at the bottom, below C, and the fuel gauge needle was dropping. turn signal lights dont work. the speedometer worked fine however. i thought the car was going to die on me, but it ran fine all the way home.
what should i check for? i already checked the connections behind the cluster.
The first thing I would do is check the under-dash fuses. My '89 CRX Si did that a couple of times, and replacing a 10 amp fuse under the dash corrected it. I still have to dig through the harness and see where the problem is originating, but for the present, I just keep a box of 10 amp fuses in the car.
Troy
Squalor, Costin', Texas
"Happiness is a loaded weapon...." -- Sisters Of Mercy
Troy
DEPintheCurve
Feb 22, 2018 03:35 AM
aznnikeballer887
May 5, 2008 11:08 PM
