Engine builders....ACL Bearings for my h22
Old Aug 4, 2005 | 05:30 AM
ludeDVR's Avatar
Default Engine builders....ACL Bearings for my h22
I've been to several sites trying to figure out the correct item number for ACL Rod Bearings for my h22a1. I know 93-97 have the 50mm and 98+ have 55mm journals. Tuners choice lists that h22a1/a4's and h23a1's are the same. ACL doesn't even have a listing for rod bearings for the h22a1 in their catalog. As far as I can read in the catalog, they specify that the h22a1 rod bearings are different than the h23a1 rod bearings. HELP! I need these rod bearings to get my block put together.
Link for ACL's catalog:
http://www.acl.com.au
Tuners choice link:
http://www.tunerschoice.com/xq...t.htm
I would trust ACL over anything else, but they don't have my h22a1 listed. TIA!
Old Aug 4, 2005 | 07:52 AM
97Preludeguy's Avatar
Default Re: Engine builders....ACL Bearings for my h22 (ludeDVR)
Bump, so this guy can get his engine back together
Old Aug 4, 2005 | 07:59 AM
mayfieldfour's Avatar
Default Re: Engine builders....ACL Bearings for my h22 (97Preludeguy)
I just bought a set of the ACL rod and main bearings from Kteller.com. I put a different crank into my 1994 h22a block, so I wasn't able to match up the colors as normal. I got a standard set and they were well within specs. Give Mike (at kteller) a call and he should be able to help you out. He knows his stuff and if he can't help you, he will find someone who can. And did you call ACL to see what they have to say? Might be a good start point as well.
Old Aug 4, 2005 | 08:04 AM
ludeDVR's Avatar
Thanks for the bump....my block is getting lonely all by itself!
Old Aug 4, 2005 | 08:09 AM
Sam1am26's Avatar
H23a1 and H22a1 rod bearings should be the same, as well as main bearings... In fact any F/H series rod bearings should be the same except for the the F23 and F20...
Old Aug 4, 2005 | 08:19 AM
ludeDVR's Avatar
Default Re: Engine builders....ACL Bearings for my h22 (Sam1am26)
Okay, i'll just order up the h23a1 rod bearings and hope i don't have to return them...lol
Old Aug 4, 2005 | 10:30 AM
l2yanE's Avatar
https://honda-tech.com/zerothread?id=715490&page=1
Contact the Poster of this thread, He just recently ordered a set for my h22 build- Very nice guy, seems really knowledgeable-
Old Aug 4, 2005 | 02:49 PM
pentaq's Avatar
Default Re: (l2yanE)
rod bearings CB-2213GP R458H
main bearings MS-2213GP M459H
this is what is written on the boxes.
Rasmusm
Jun 17, 2013 10:37 AM
jakscivic
Feb 21, 2013 08:27 AM
Alex EX
Dec 8, 2006 10:56 PM
hondaballs
Nov 22, 2005 01:16 PM
