Head Gaskets Head Gaskets! Featuring Cometic and Golden Eagle
Please PM or email us at sales@hybrid-performance.com for all your questions, concerns, price quotes and applications available. Please
Cometic MLS gaskets is comprised of 3 layers of stainless steel. Cometic uses stainless steel for increased strength , its ability to rebound and corrosion resistance. The Viton coating is heat resistant to 250c or 482f.
- Utilizes "Factory OEM" gaskets for optimum performance
- Almost all bore sizes available
- Dowel holes are opened on B-series gaskets to accept any head/block combo
Modified by Hybrid-Performance.com at 5:57 AM 12/17/2006
Modified by Hybrid-Performance.com at 1:26 PM 1/8/2007
Modified by Hybrid-Performance.com at 7:16 AM 10/25/2007
Modified by Hybrid-Performance.com at 8:52 AM 11/6/2007
im looking for
Cometic head gasket for B18C1 gsr motor. must be stock bore and be .074 thick.
Let me know if you can get it or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">im looking for
Let me know if you can get it or not.</TD></TR></TABLE>
Yes we can order it for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com »</TD></TR><TR><TD CLASS="quote">
PM me how much.
Thanks!
</TD></TR></TABLE>PM me how much.
Thanks!
Hello there I needed advice on my setup. I have a step deck h22 block with stock bore using the oem honda gasket. i started it for the first time and when it was fully warmed up coolant started leaking between the head and block. i took the head a apart to get the surface checked out and it was straight. the guy at the machine shop took a look at the head and said the gasket needed to be .025 overbore because the sealing ring was to close to the cumbustion chamber. So my question is does GE do the .025 overbore on the headgasket and also at the same time move the sealing ring over .025 from stock? Do u recommend any other headgaskets other than stock for step deck? what headgaskets to stay away from for step deck? THanks in advance!!
