d series starter...all the same?
i am going to the junkyard tom to see if i can pick up a used starter for my d16y7, but i want to know if any sohc d series engine starter will work for my 96 civic?
can anyone please enlighten me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Manual starters all the same
Auto starters all the same.
Can not mix auto with manual and vice versa. </TD></TR></TABLE>
I can confirm that. Only because he did my auto to manual haha.
From: With my POS D15B2, Whereever whenever, United States
If you take the base, motor of a auto starter, you can fit it in a manual gearset, but you will need to extend the wire.
I know because I tried, however the gears don't quite mesh up.
I did this and it worked for a good 3-5 months until the auto finally gave up because the gear space is TIGHT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparxx »</TD></TR><TR><TD CLASS="quote">I would like to know if a d15b7 starter will fit and work on a d16z6.thanks</TD></TR></TABLE>
yes i did this today
