obd0 to obd1 help
Old Aug 3, 2005 | 10:12 PM
ceaz's Avatar
Default obd0 to obd1 help
i got an ef9. im puttin a sohc vtec obd1 i got the jumper harness i nedd help with wireing the jumper harness i need steb by step literature and diagrams if possible thanks
Old Aug 3, 2005 | 10:50 PM
gnar kill's Avatar
Default Re: obd0 to obd1 help (ceaz)
don't those come with the wiring harness....the wiring is cake.....you onle have to wire in like 9 wires and they, 4 are o2, 1 vtec selenoid,1 for vtec pressure, 2 for a switch to check codes.......don't worry about the knock sensor or the secondary runners one for a b18c
Old Aug 4, 2005 | 01:21 AM
ALLMOTORCRX20's Avatar
gnar kill is right. Its only a couple wires. It would not be a bad idea if you can get a copy of the wiring diagram for a 92-95 civic and also for a 88-91 civic SI so you can trace all the wires. Since your running a sohc vtec engine you only have to connect 6 wires. Did you get a 4 wire oxygen sensor?? If not, you can still run your car with the oxygen sensor that is in your car, but it will throw a check engine light. It wont harm anything. If your running your 1 wire oxygen sensor, then you only need to connect 3 wires (oxygen sensor signal, vtec pressure and vtec solenoid)
Old Aug 4, 2005 | 06:51 AM
ceaz's Avatar
.do i use ths obd1 eg wireing harness or the one in my blown motor?
Old Aug 4, 2005 | 07:30 AM
ceaz's Avatar
like the obdi distribuitor plug end the vtech selenoid plug riight?
vtecpros
Mar 12, 2010 12:38 AM
vtecpros
Mar 3, 2010 05:55 AM
ef dino
Jun 1, 2007 07:04 AM
ek9vboi2
Jun 24, 2005 07:44 PM
topsekret
Dec 21, 2002 05:43 AM
