clutch slave replacement
Old Aug 3, 2005 | 09:39 PM
illusion's Avatar
Default clutch slave replacement
does anything need to be removed from the engine bay before removing the clutch slave cylinder?
it looks kind of tight to get tools in there and to remove/replace it..
Old Aug 3, 2005 | 09:49 PM
4LugR's Avatar
Default Re: clutch slave replacement (illusion)
nope, just get a line wrench, and its easy. even without one its easy. i did mine in an hour with an adjustable wrench, and i have full AC and everything.. just the two bolts on the front and the line on top
Old Aug 3, 2005 | 09:50 PM
illusion's Avatar
Default Re: clutch slave replacement (AEMPrelude916)
i didnt know what size that bolt was on the clutch line that goes into the slave cylinder
i came home with a 10mm flare wrench and 9mm open ended. hopefully one of those will do?
Old Aug 3, 2005 | 09:56 PM
4LugR's Avatar
i think it is a 10. or a 9... so your good either way, since you have both
and then i think the two bolts on the top are 12's...
Old Aug 4, 2005 | 09:13 AM
RemerLex11's Avatar
have fun getting those two bottom bolts back in haha unless you have small *** hands its frustrating as hell.
Old Aug 4, 2005 | 01:32 PM
prelude1897's Avatar
Default Re: clutch slave replacement (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">have fun getting those two bottom bolts back in haha unless you have small *** hands its frustrating as hell.</TD></TR></TABLE>
Very true unless if you've done it a few times....If its your first time, it get's pretty frustrating
Old Aug 4, 2005 | 04:30 PM
illusion's Avatar
haha dude as i was doing this this morning, i was thinking to myself "WTF this guy said this was supposed to be an easy swap!"
i have big hands and it was a pain in the *** trying to compress the cylinder and get the bolts in at the same time. i think i got lucky and the hole lined right up.
Old Aug 4, 2005 | 04:34 PM
PrettyLude's Avatar
its not as hard as people make it out to be, just take out the fan, and bam, you have plenty of room to work with
Old Aug 4, 2005 | 04:59 PM
illusion's Avatar
Default Re: (PrettyLude)
yea you are exactly right.
if i knew how to remove those fans in the front i wouldve saved half the time! matter of fact, i would say that most car maintenance isnt that difficult, but half the time you lose is becuase
1. working at **** angles
2. fitting hands/tools into small areas
3. dropping tools/bolts and getting them out
god damnit.
Old May 3, 2006 | 07:07 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (illusion)
my clutch slave cylinder is going out on me, or at least I think it is. I am losing fluid and sometimes when I press on the clutch it will stay down to the floor and i have to pull it up with my feet. Is that a problem that the slave cylinder would cause? or is it something bigger?
Also, Can someone post pix of where the cylinder is on a 4th Gen? I want to do it myself and not pay to have it done.
Old May 3, 2006 | 07:14 AM
mgags7's Avatar
anthony, that could be any part of the clutch hydraulic system causing that, check the master cylinder, the line all the way from it, across the firewall, down to the damper, from there to the top of the trans, and then down to the slave (black thing with line into the top) on the front of the transmission....
Old May 3, 2006 | 07:17 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (mgags7)
If I keep my clutch fluid full it doesnt do it, and I have no problems. Its only when I lose the fluid, thats when my clutch will stick.
Old May 3, 2006 | 07:20 AM
mgags7's Avatar
yes, which would indicate that you have a leak somewhere that needs to be fixed
of course the pedal sticks when you lose fluid dude, read up on basic hydraulics
Old May 3, 2006 | 07:24 AM
AnthonyG2003
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">of course the pedal sticks when you lose fluid dude, read up on basic hydraulics</TD></TR></TABLE>
I understand the basics of it. I was just adding more info to maybe get some additional help.
The leak is on the passanger side. I will try and trace all the lines and try to see if I can locate the leak...But I havent been successful yet.
Default Re: (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">If I keep my clutch fluid full it doesnt do it, and I have no problems. Its only when I lose the fluid, thats when my clutch will stick.</TD></TR></TABLE>
defenitly sounds like either your master or slave cyclinder is leaking. Either way, you should change them both out
Old May 3, 2006 | 07:27 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (prelude1897)
why would you suggest changing them both out?
Old May 3, 2006 | 08:44 AM
mgags7's Avatar
because its easier to do them both while youre in there
Old May 3, 2006 | 09:02 AM
akber's Avatar
is it possible to get any sort of "upgraded" slave and master cylinder? sorry i dont know much about trannies
Old May 3, 2006 | 09:49 AM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">because its easier to do them both while youre in there</TD></TR></TABLE>
That and because the master will now be the weak point in the system (If it hasent been recently changed). Better to change them both at once so you dont have to bleed again.
Old May 3, 2006 | 10:34 AM
esedulerp5tenin's Avatar
Default Re: (mkazm83)
http://www.nopionline.com/nopi...01995
tokico slave cylinder for $23
Old May 3, 2006 | 10:40 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (esedulerp5tenin)
I have looked at my slave cylinder now and I dont see any fluid around it. I am seeing the fluid farther back...If you look at the vtec sileniod and then look straight down...I am seeing fluid there...I don't know where that could be coming from...any other suggestions?
Old May 3, 2006 | 02:37 PM
piggydog's Avatar
what would be symptoms that you need to change the cylinder? lately it's getting harder to put it in 1st or 3rd gear for me
Old May 3, 2006 | 03:44 PM
NoVALude's Avatar
Default Re: (piggydog)
I had fluid leaking in the cabin (down the back of the clutch pedal) and some leakage around the clutch cylinder as well..never really felt that bad when I used it, just noticed fluid on the pedal.
tried to take the damn cotter pin out and some sadistic bastard put the thing in upside down (so the rounded end is toward the dashboard, instead of toward the floor so you can grab onto it and yank)
besides putting the old cyl. back on, anyone have any ideas to get the damn cotter pin out????
chris89
Aug 13, 2015 03:32 AM
Shurt24
Jun 25, 2014 08:59 PM
matryx
May 5, 2008 06:08 PM
skata89
Mar 31, 2006 02:41 PM
stRtypR25
Jan 23, 2003 05:29 PM
