92 integra b18a into 89 crx-si help
Old Aug 3, 2005 | 09:24 PM
mauibuilt's Avatar
Default 92 integra b18a into 89 crx-si help
i need help with converting all the obd1 to obd-0 or vice versa, i used the si harness and hooked everything up running off the si ecu but it wont start, all the threads i read are 90-91 b18s which drop right in using stock harness and ecu but i happen to have the obd 1 92 b18a what do i do!!! thanks all who help!!!
Old Aug 3, 2005 | 09:52 PM
DohcVtecCrx's Avatar
Default Re: 92 integra b18a into 89 crx-si help (mauibuilt)
ecu conversion harness obd-0 to obd-1
rywire.com and boomslang.com both sell good kits and have great support/instructions on how to do it.
Old Aug 4, 2005 | 01:13 AM
ALLMOTORCRX20's Avatar
You used a 92 b18a in your crx with the 88-91 crx si obd-0 harness. Im guessing you also used the 88-91 crx si distriubor and oxygen sensor. Was the distributor in your other engine or can you guarantee that its a good one?? do you know if you have spark?
Old Aug 4, 2005 | 07:50 AM
gmptep1's Avatar
Default Re: 92 integra b18a into 89 crx-si help (ALLMOTORCRX20)
i have a 98 LS in my 90 civic, i used all the OBD0 parts and a white plug 90-91 LS distributor, it should run and start fine, LS ECU no problems
Old Aug 4, 2005 | 11:06 AM
Hondaracer197791's Avatar
I got a 91 LS in my 91 Hatch, and I had to use Si wiring harness to make it run. The LS harness doesnt plug n play with the body.
Old Aug 4, 2005 | 01:10 PM
mauibuilt's Avatar
thanks for all the help guys i ended up just buying the wiring harness from boomslang and overnighted it.
DA john
15
Mar 23, 2013 12:45 PM
DualCamDan
10
Feb 4, 2006 05:12 AM
nate_d
Dec 4, 2004 12:59 PM
RACINTWEEK
May 27, 2004 02:09 PM
derekellison
Nov 18, 2003 11:22 PM
