wierd problems with rotors, somebody shed some light please.
i reciently purchased front and rear sets of brembo slotted rotors. im not at my house so i dont have the part number for the front. the rears went on without a hitch but the front , the hubs were bigger than the inner diameter of the rotor so it wouldnt fit over , it was a 5x114.3 pattern , looks exactly like my stock rotors in the front but on the back , the hole that the hub goes through is about a half an inch bigger in diameter on the stock rotors. did i get prelude rotors by mistake or something? has anyone ever experienced this ??? im stumped
**** salt
**** salt
It's quite possible that they gave you rotors for another car. Prelude is a good guess.
For example, the center bore of the wheels (this is the center hole, for the part of the hub that the wheels fit over - not the size of the hole on the rotors) is 64 mm on all four corners of the ITR. On other cars, the center bore is not necessarily the same front and rear; for example, with the NSX, it's 64 mm on one axle, 70 mm on the other.
Take 'em back.
Take 'em back.
ya im talkin to stopchek right now about taking them back . does anyone know the part no to brembo front rotors?
bump , does anyone know the part number to brembo front rotors??? so i can make sure i have the right ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">bump , does anyone know the part number to brembo front rotors??? so i can make sure i have the right ones?</TD></TR></TABLE>
bumping is not allowed in here.
and you could find the # by using the search or contacting Brembo direct.
As well, you could just return the brembo slotted stuff and get Autozones that not only fit but are usually less than half the price of the slotted brembo things.
If he wants to get Brembo, let him get Brembo. Let's try to help him out instead of attacking him because he gets something different from what you (or I) use.
Have you tried looking on the Brembo website? Click on High Performance, then on Sport Brakes or GT Brakes, then on Sport Catalogue, then on Discs...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Have you tried looking on the Brembo website? Click on High Performance, then on Sport Brakes or GT Brakes, then on Sport Catalogue, then on Discs...
Integra isnt listed in the application guide on the website.
descartesfool
35
Jul 30, 2012 08:04 AM
egjdm03
21
Sep 12, 2004 09:17 PM
