compression test ?
Old Aug 3, 2005 | 08:39 PM
Got_soy's Avatar
Default compression test ?
will a compression test tell me if my rings are bad, or do i also have to do a leak down test as well. I have a d16a6 that burns oil like sadam in the gulf war
Old Aug 3, 2005 | 08:48 PM
Suck my DX's Avatar
Default Re: compression test ? (Got_soy)
compression test is to test how much compression is in ur cylinder...it doesnt point out where its leakin from...thats what a leakdown test is for....it shows u how much air is escaping and u can figure out from where
Old Aug 3, 2005 | 08:50 PM
b18_crx's Avatar
Default Re: compression test ? (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">compression test is to test how much compression is in ur cylinder...it doesnt point out where its leakin from...thats what a leakdown test is for....it shows u how much air is escaping and u can figure out from where</TD></TR></TABLE>
damn pretty much thats it. IF UR MOTOR HAS LOW COMPRESSION IT COULD BE many things D16a6 more than likely rings
Old Aug 3, 2005 | 08:53 PM
Got_soy's Avatar
i had a compression test done and the guy said it was good. i havent gotten my
car back to i dont know what any numbers are either. i asked if he could to a leak
down and that was also good. (this was all told to me by my friend who took it in
for me ) What i'm wondering is were is the oil coming from then?
Old Aug 3, 2005 | 08:56 PM
RCautoworks's Avatar
Check your brake booster valve, I have seen these malfunction, and it would suck up brake fluid, but your master cylinder has to be leaking a little, which in older cars, all master cylinders usually leak a little.
How do you know for sure you are burning oil and not something else, like brake fluid, or atf ?
Old Aug 3, 2005 | 09:01 PM
Got_soy's Avatar
Default Re: compression test ? (90blackcrx)
Blue smoke
Old Aug 3, 2005 | 09:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">Blue smoke</TD></TR></TABLE>
So do you loose oil ? Do you have to fill her up ?
Old Aug 3, 2005 | 09:05 PM
Got_soy's Avatar
yes, ive read some wear that valve guides go bad, could that be whats leaking oil
Old Aug 3, 2005 | 09:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">yes, ive read some wear that valve guides go bad, could that be whats leaking oil </TD></TR></TABLE>
But you said the leakdown and compression test were good, sounds like something is not adding up here.
Old Aug 3, 2005 | 09:11 PM
Got_soy's Avatar
yeah i know my friend told me what the mech. told him.
Old Aug 3, 2005 | 09:14 PM
Get the numbers then report back with them.
Old Aug 3, 2005 | 09:17 PM
Got_soy's Avatar
i was just trying to get a general idea of what could go wrong
Old Aug 3, 2005 | 09:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">i was just trying to get a general idea of what could go wrong
If its burning oil, you are getting oil in the combustion chamber some how. Reasons could be
Bad rings
Bad valve seals
Right now those are the two main things I can think of, its late so I'm probably leaving something out.
Maybe pull your valve cover off and see if you're dripping oil from there, I have seen some bad valve cover gaskets, where the oil will leak down in the tube, and all the one down on the spark plug electrode.
Old Aug 3, 2005 | 09:23 PM
Got_soy's Avatar
my gf saturn does that, i changed her spark plug and two were swimming in oil
Old Aug 4, 2005 | 01:14 AM
ALLMOTORCRX20's Avatar
You could also have a leak somewhere in the engine and not know it. I thought my integra was burning oil too, but one of the bolts that goes to the oil pan was missing and it was enought to cause an oil leak through there. It never made a puddle on the ground. You might wanna check that and other sensors around the engine if all your reading are good.
Old Aug 4, 2005 | 11:12 AM
Hondaracer197791's Avatar
Check the pcv valve. Take it out and shake it. If you hear something rattling inside it is good, If not it is clogged, casuing oil blow-by. The oil then goes into the intake, and burns in the combustion chamber.
Old Aug 4, 2005 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">my gf saturn does that, i changed her spark plug and two were swimming in oil </TD></TR></TABLE>
One of the main cars that has this problem is Saturn, and last time I checked, for some reason GM did not make gaskets for the older Saturns, so you needed to use gasket maker a lot. Maybe because it was the first year of the saturn, and it was more like a proto type thing. Or maybe because it was GM
Old Aug 4, 2005 | 01:50 PM
Got_soy's Avatar
good to my friend means a whole different thing to me. No leak down numbers. #1-185 #2-175 #3-175 #4-150. im ASSUMING #4 the reason im buring oil now
Old Aug 4, 2005 | 01:53 PM
Suck my DX's Avatar
looks like ur gonna have to rebuild soon...might as well drive it till it blows and swap in a dual cam
Old Aug 4, 2005 | 02:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">good to my friend means a whole different thing to me. No leak down numbers. #1-185 #2-175 #3-175 #4-150. im ASSUMING #4 the reason im buring oil now</TD></TR></TABLE>
I knew the compression numbers were gonna be like that, by the way, those are not good compression numbers like your mechanic said.
Old Aug 4, 2005 | 03:40 PM
Got_soy's Avatar
yeah i know i was expecting different digits and definitly not 150. is there anything i can do to slow the oil consumpiton? thicker oil maybe?
Old Aug 4, 2005 | 06:33 PM
Got_soy's Avatar
sombodys got an answer
Old Aug 4, 2005 | 06:42 PM
sanimalp's Avatar
$cat /dev/urandom
well, my old prelude burned oil like a SOB, and i put in some valvoline maxlife oil, and it got rid of the smoke. i think my valve seals were pretty bad in it cause it had 250k without a rebuild. try that.
Old Aug 4, 2005 | 06:47 PM
LSVTEC 91 Civic's Avatar
Banned
Try running Chevron Delo 15w-40 oil, It'll slow down the burning of oil until you get it rebuilt.
Old Aug 4, 2005 | 06:55 PM
Got_soy's Avatar
Default Re: compression test ? (LSVTEC 91 Civic)
about how much would a rebuild go for? would it be cheaper to get a single cam zc?from hmo
