JDM Cluster...Now car starts hard...WTF?
Old Aug 3, 2005 | 07:48 PM
BTP's Avatar
BTP
Default JDM Cluster...Now car starts hard...WTF?
Like it says in the title. After installing the cluster the car starts hard. I checked the battery and it was 100%. Next I unplugged the JDM cluster and it started with no problems. Is there something I can check on the cluster itself?
Thanks
Old Aug 3, 2005 | 09:51 PM
niccuhles's Avatar
cause anything JDM makes your car have more power! jk. free bump cause i wanted to make a joke.
Old Aug 3, 2005 | 10:34 PM
howangseg's Avatar
Default Re: JDM Cluster...Now car starts hard...WTF? (BTP)
what do you mean starts harder? do you mean its harder to start?
Old Aug 4, 2005 | 10:15 AM
b204dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BTP &raquo;</TD></TR><TR><TD CLASS="quote">Like it says in the title. After installing the cluster the car starts hard. I checked the battery and it was 100%. Next I unplugged the JDM cluster and it started with no problems. Is there something I can check on the cluster itself?
Thanks</TD></TR></TABLE>
maybe unplugging some thing/ pluggin in you blew some fuses - shouldnt really affect how your car is running
Old Aug 4, 2005 | 10:59 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: JDM Cluster...Now car starts hard...WTF? (b204dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr &raquo;</TD></TR><TR><TD CLASS="quote">
maybe unplugging some thing/ pluggin in you blew some fuses - shouldnt really affect how your car is running </TD></TR></TABLE>Yeah there aren't any components in the gauge cluster that effect the operation of the engine.. Starnge, BUMP for any suggestions..
Old Aug 4, 2005 | 11:41 AM
EeeJayEight's Avatar
Default Re: JDM Cluster...Now car starts hard...WTF? (HondaFanatic708)
cluster would have nothing to do with it..
and for the comment about the fuse.. he said that the car started fine when i removed the cluster so i dont think the problem is there...
unless there is a short of some kind in the cluster that is causing some current to be drawn from the battery minimizing its voltage capacity?
Old Aug 4, 2005 | 11:49 AM
Default Re: JDM Cluster...Now car starts hard...WTF? (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">cluster would have nothing to do with it..
unless there is a short of some kind in the cluster that is causing some current to be drawn from the battery minimizing its voltage capacity?</TD></TR></TABLE>Could be however this would be pretty hard since it isn't wiring but a sort of flex-circuit board..
Old Aug 4, 2005 | 12:52 PM
alleyezonme's Avatar
That would be the only thing that makes sense to me would be a short somewhere. try double checking all the wires for any exposed metals. Good luck man, I haven't heard of this problem yet!
Old Aug 4, 2005 | 01:22 PM
Relic1's Avatar
it more than likely is something you unintentionally did rather than a result of the cluster being there.
maybe if the cluster's tach is messed up and shorts out the tach signal the ECU wouldn't see the engine turning and would not start it.
Old Aug 4, 2005 | 11:10 PM
Default Re: (Relic1)
instead of plugging in all the plugs... try each one seperate and see which one is giving u the trouble then let us know and maybe we can help u out better
Old Aug 4, 2005 | 11:12 PM
eg6sir-s's Avatar
Default Re: (EeeJayEight)
its all in your head. its just a cluster nothing more nothing less.
brutekiller787
21
Dec 2, 2009 11:34 PM
teg_dc2
Aug 25, 2008 07:32 PM
BpuTacoma
Jul 5, 2004 09:55 PM
OmegaLS
Nov 10, 2001 10:10 PM
