Honda S2000 Honda S2000
I need help on my s2k( replacing lower control arms)
Old Aug 3, 2005 | 06:27 PM
agapeBB6's Avatar
Default I need help on my s2k( replacing lower control arms)
Ok I have been trying to replace the lower control arms.
Here is the diagram
I have took out all the bolts, but I got stuck with #25 and #13.
I was told to burn off the bushing that covers the #13 since it was torn and to free the collar(#13) from the arm, so the arm is free, but I can't still get that #13 out.
I even got some progress pics here.
#25 I tried to knock this out with the hammer, but no luck.
I don't get much help on s2ki.com forum, can anybody give me some suggestions here?
Old Aug 4, 2005 | 11:32 AM
Mr. Bagel's Avatar
Default Re: I need help on my s2k( replacing lower control arms) (agapes2k)
corrected image here:
Old Aug 4, 2005 | 11:58 AM
Luder94's Avatar
Ughhh...alignment bolt sux the big fat one. You'll need an impact wrench and need to spin it tight and loose in success from the wobble side (the oval side of the bolt) after you take the nut off the other end. It also helps to load the suspension once you take the nut off.
Keep at it. If it doesn't spin after some time, take a large mallet and give it a few good pounds from the non-wobble side. Then back to impact gunning it off.
If all else fails, drop the rear subframe assembly so that you can get a better angle on those bolts. I've had to do this for a couple of local owners' cars I worked on in the past. They had just gotten so seized, there was no other option.
Hope that helps.
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
mitchell_2kSiR
Suspension & Brakes
Jan 7, 2008 06:31 AM
yaughtben
Aug 28, 2007 08:56 PM
jdmunzip
Sep 5, 2006 03:51 PM
markwitdada9
Jan 31, 2006 05:15 PM
