Can I remove the whole map sensor from the wall?
Old Aug 3, 2005 | 06:11 PM
88 rex's Avatar
Default Can I remove the whole map sensor from the wall?
If converting to OBD1, can I remove the wall mounted map sensor along with whatever else it is attached to? I was hoping that the charcoal canister, wall mounted map sensor and whatever is connected to it can be ripped out.
I'm pretty sure i can rip out the charcoal canister and use my map sensor on the TB w/ no issues, but what else is mounted with the stock map sensor that I might need?
Thanks
Old Aug 3, 2005 | 06:54 PM
eda6's Avatar
Default Re: Can I remove the whole map sensor from the wall? (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure i can rip out the charcoal canister and use my map sensor on the TB w/ no issues, but what else is mounted with the stock map sensor that I might need?</TD></TR></TABLE>
you can definately remove the map sensor since it's been relocated to your tb. The other thing is the evap purge solenoid. It can be removed as well. One of the hoses that goes to the charcoal canister is the vent tube for the gas tank. Don't cap it off, make sure it's open to the atmosphere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">If converting to OBD1</TD></TR></TABLE>
All the obd0 people can do this too.
Modified by eda6 at 11:05 PM 8/3/2005
Old Aug 4, 2005 | 04:58 PM
88 rex's Avatar
Default Re: Can I remove the whole map sensor from the wall? (eda6)
Thank you
kpowerdhatch
Oct 20, 2007 02:43 PM
methos713
Jun 11, 2007 12:43 PM
'90crxSI
May 23, 2006 06:53 AM
B18C-RnVA
Aug 19, 2002 03:07 PM
