Rack and Pinion Problems
probably quite a bit if you have it done at a shop because i think you would have to take out the motor just to do it... Maybe you can get by doing it without pulling the motor out.
do it urself tho and u wont have to worry about payign someone too much to do it!
I got mine replaced at a local Honda dealership a couple of years ago. They bent me over and stuck it to me, I forgot the exact price but it was like $700-$800. I have records around here somewhere and I'm sure I can find it if you need an exact #. Wish I could have done it myself because the parts weren't all that expensive but the labor was like $500 if I remember correctly
I've done a rack and pinion on a friends car and it was very difficult to pull out as one-peice. A shop will charge you a good amount because either they will take off the rear mount and pull it out or pull out the motor.
Good luck
Good luck
mighty_sol
Jun 21, 2007 11:21 AM
KevronsEG
Feb 8, 2003 08:17 AM
