vibrating issue
Old Aug 3, 2005 | 05:10 PM
wacrxguy's Avatar
Default vibrating issue
Well I am hoping someone can help me with this problem. When I step on the brakes lightly at any speed above about 15 MPH the steering wheel shakes like it is a brake problem. If I get on the brakes hard I dont feel anything it is just under normal braking that I can feel it. I dont think it is anything with the brakes though because I had the problem with the old brakes put new calipers disk and pads on the front of the car and it is still there. Could this be maybe a bad tie rod? I jacked up the car and tried to see if I had any play in the wheel and couldnt find any. I really need to try to get this fixed before the next track day that is coming up. Thanks for any advice you guys can give me.
Old Aug 3, 2005 | 06:04 PM
Its me DUB's Avatar
Default Re: vibrating issue (wacrxguy)
Warped rotors? Bushings?
Old Aug 3, 2005 | 06:29 PM
hotimportcrx's Avatar
Default Re: vibrating issue (doitdub)
motor mount......if the car is shaking hard when u break and the faster u go the harder it shakes its probably the motor mount...because i was going like 80mph and the car was like doom doom doom and starting shaking so hard you counlt control it....that was bad ....its because i ignored the problem when the mount was starting to go
Old Aug 3, 2005 | 07:56 PM
wacrxguy's Avatar
rotors are brand new so I know that there isnt a chance in hell that I have warped those Brembo Blanks. I also have all new bushings in the whole car. Energy suspension with the exception of the rear trailing arm where I have the mugens.
HHMMMM The motor mounts this is more of a pulsing and the vibration dosnt get any worse with increased speed you just dont notice it below 15 or so and only when you are on the brakes normally if I stand on them like right before the point of locking them up. There is no pulsing anyone else? It is quite a mystery to me.
Old Aug 3, 2005 | 08:03 PM
thapimpfromchi's Avatar
i dunno, i have the same problem, i think... my friend suggested a bad ball joint. said its a cheap 70 dollar fix, but i wanna make sure its that before i spend the 70 bucks.
Old Aug 3, 2005 | 08:12 PM
wacrxguy's Avatar
which ball joint does he think it is I have replace my whole upper control arms
Old Aug 5, 2005 | 09:11 AM
not sure at all man. thats all he said.
Old Aug 5, 2005 | 10:42 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (thapimpfromchi)
hey, i have the same problem.. i am trying to work out what my problem is. here is a link to the topic. https://honda-tech.com/zerothread?id=1322861 so far i have replaced rotors, and the pads are flat.. i am deffinetly thinking that something in the suspension is mess up now. i am also thinking that ball joints could be a problem, and a person also mentioned wheel bearings. both of us are in the same money situation as well, where i would like to find the cheapest solution to mine, but i am starting to think that my problem wont be fixed unless i spend the money on ball joints and wheel bearings.
bibong
Feb 6, 2007 01:01 PM
Anthrolude
Mar 4, 2005 06:42 AM
egg_baLLa
Feb 1, 2005 07:23 AM
morana622
Jan 27, 2005 11:36 AM
blkbeast
Apr 18, 2002 07:54 AM
