Pls help me identify.... I'm lost
Old Aug 3, 2005 | 04:34 PM
VeilSide_Mas's Avatar
Default Pls help me identify.... I'm lost
I bought this parts from ebay and the seller claims its from an SI but i doubt it.... could anyone pls let me know what i lack for the conversion and which car is the parts below from?.... thank you so much....
the seller said the t/b is from f22 accord... do u think it could be used?
Why does the fuel rail in the above picture wouldnt align... is that a wrong fuel rail?
It aligns does that mean it will fit?
11
Modified by VeilSide_Mas at 9:59 PM 8/3/2005
Old Aug 3, 2005 | 04:36 PM
btw , it came with a engine harness and a si distributor....
on the manifold itself could i knwo what is lacking..... and where i can get those parts from?.....
behind the intake manifold its written PM6 then 2 HF
Old Aug 3, 2005 | 06:17 PM
Bserieskllr's Avatar
its a intake manifold for a crx/civic si so for d-series the fuel rail looks like the wrong one and number 8 looks like a z6 fuel rail.
Old Aug 3, 2005 | 06:29 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: Pls help me identify.... I'm lost (VeilSide_Mas)
Want to sell me that idle air control valve off that manifold?
Old Aug 3, 2005 | 06:48 PM
err no because i need to do a conversion.... no more info?
Old Aug 3, 2005 | 07:05 PM
91civicEX's Avatar
Default Re: (VeilSide_Mas)
looks like you got a hf manifold? with a non hf throttle body maybe. that vacuum line fiting near the tb isnt there on my si manifold
Old Aug 3, 2005 | 07:22 PM
Can anyone post me some pictures for comparison so i can decide to just buy another manifold altogether.
Old Aug 4, 2005 | 06:55 AM
anyone pls?
Old Aug 4, 2005 | 08:46 AM
ninjarico's Avatar
That's an HF intake manifold.
Old Aug 4, 2005 | 09:08 AM
vegaskurt's Avatar
Default Re: (ninjarico)
there is probably nothing wrong with that manifold for your conversion. The fuel rail definitly does not go to it so I would find a new one. As for the throttle body I cant comment, but the bracket for the throttle cable looks like it is on the wrong side.
Old Aug 4, 2005 | 09:39 AM
how do u know if its an SI manifold then?
am i missing any sensors on the manifold?
and what are the size /hp difference of the hf and si intake manifold?
Old Aug 4, 2005 | 06:13 PM
no one?
Old Aug 4, 2005 | 07:02 PM
JDM Panda's Avatar
if your gunna do something like that, just sell it and get a y8 manifold..
Old Aug 4, 2005 | 08:20 PM
that is not an hf manifold the tb port is to big its an si
Old Aug 4, 2005 | 09:29 PM
y8 manifold? whats the benefit of the y8 over this one?
Bserieskllr: nice car u have 14.1 sec wow.... but behind the intake manifold.... its printed HF-2 , i dont know where the t/b come from.....
would really hope to get some advise here......thank you so much
Old Aug 4, 2005 | 11:20 PM
cmyrex's Avatar
That tb looks too big to be an hf. So i agree it looks like an hf set up with some weird odds in ends. I would sort that out with whoever sold you that on ebay.
Old Aug 5, 2005 | 12:20 AM
Tyson's Avatar
the identification of the intake manifold is in the top left corner of pic #1. if it says PM6, its DEFINATELY an Si. the 2HF means nothing related to "HF" model.
you can also tell because theres two holes on the bottom for the stay bracket. the HF manifold only has 1 hole for the bracket. also, the runners on the HF manifold are crazy small, youd be able to tell visually that its an HF.
ITS FOR SURE AN SI MANIFOLD.
however, the fuel line shown in the pic 7 is from an HF. its missing a piece where the cover is. you can tell its definately not an Si because the plastic cap thingy is in the top of the rail. it should be at the end of the fuel rail, instead the HF has the piece that is shown missing.
the throttle body you said is an F22. i have no idea if it will work properly, but i wouldnt take your chances.
the fuel rail shown in pic #8 is probably from a Z6. no idea if it fits the Si manifold either.
Old Aug 5, 2005 | 12:42 AM
JDM Panda's Avatar
Nvm your not doing a mini me, I wasn't paying attention my bad.
Old Aug 5, 2005 | 04:47 AM
crx_88_si's Avatar
Si Manifold from an 90-91 crx/civic
Old Aug 5, 2005 | 06:33 AM
92integra_gs's Avatar
looks like an HF to me also...
i would send it back and get my money back...
Old Aug 5, 2005 | 08:46 AM
thanks a lot everyone...appreciate the info.......
Old Aug 5, 2005 | 02:23 PM
gosh , could someone pls help me verify if its a hf or not... i dont know who to belief now.
Old Aug 5, 2005 | 03:11 PM
Tyson's Avatar
its a 100% an Si manifold with a HF fuel rail.
this is an HF manifold in the picture. you can see the vacuum lines are not even the same as the Si.
here is ANOTHER picture of a HF engine. here you can see the fuel rail with the plastic cap in the middle of the rail, which is NOT where it is on the Si manifold.
ppl are guessing without even reading. no wonder you dont know who to believe.
Old Aug 5, 2005 | 04:27 PM
ah thanks for clearing that up... now it seems so clear to me already...
Old Aug 5, 2005 | 10:19 PM
vegaskurt's Avatar
Here is my si manifold and fuel rail. Just so you can compare.
http://www.4gcivic.net/gallery2/main.php
To bad I just sold it or I would hook you up.
superfly831
Jun 20, 2012 04:27 PM
ef0cmacro
May 21, 2007 06:44 AM
ef0cmacro
May 20, 2007 07:17 PM
Aceman64
Apr 20, 2003 10:25 AM
