Suspension & Brakes Theory, alignment, spring rates....
cheapest camber correction kit??
Old Aug 3, 2005 | 04:24 PM
torqueless's Avatar
Default cheapest camber correction kit??
just put some 16" on my car, and know they are toed in. is it possible to have an alignment with stock? how so if you cant adjust them?? anyway, i found a tire shop that sells no name brand for $40 ea. wich is pretty cheap. any better deals than that???
Old Aug 3, 2005 | 04:28 PM
Tyson's Avatar
Default Re: cheapest camber correction kit?? (torqueless)
toe or camber? front or rear?
Old Aug 3, 2005 | 04:31 PM
torqueless's Avatar
Default Re: cheapest camber correction kit?? (Tyson)
im confused, i thought camber is when the tire is toed in or toed out(neg or pos.) but its toed in.
Old Aug 3, 2005 | 04:34 PM
Tyson's Avatar
yes, you are confused.
this is (negative) camber. looking at the front of the grill: / \
this is toe (in). looking from above. / \
which is it?
http://www.ozebiz.com.au/racet....html
torqueless's Avatar
also its a little castered inwards. and its just the front tires
Old Aug 3, 2005 | 04:35 PM
torqueless's Avatar
oh,, both lol. but more negitive camber than toed in
Old Aug 3, 2005 | 04:37 PM
Tyson's Avatar
just fix your toe. get an alignment.
Old Aug 3, 2005 | 04:38 PM
torqueless's Avatar
ok thanks man will an alignment also fix the negative camber
Old Aug 3, 2005 | 04:44 PM
Tyson's Avatar
no. the only adjustment in a normal alignment is toe.
negative camber is beneficial to handling. dont try to get rid of it.
Old Aug 3, 2005 | 05:25 PM
torqueless's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">no. the only adjustment in a normal alignment is toe.
negative camber is beneficial to handling. dont try to get rid of it.</TD></TR></TABLE>
oh really? thats cool, i just dont want it to wear faster though
Old Aug 3, 2005 | 05:26 PM
Tyson's Avatar
the myth that camber creates tire wear when lowering is wrong. its the change in toe that causes the uneven tire wear. toe is corrected by an alignment. negative camber is beneficial to handling, especially when lowered.
the difference of a cambered tire is that the tire is moving along the direction of motion relative to the street. theres no more friction than rolling resistance. plus, a tire will flatten out at the contact patch. a badly toed tire is forcing the tire to move against the motion relative to the street, like its constantly turning.
Old Aug 3, 2005 | 08:14 PM
JesseCRX's Avatar
Whats a good negative camber setting for a 2.5 inch drop?
Coopa B18c5
Jan 18, 2013 07:58 PM
hatch96y7
Oct 13, 2007 09:27 AM
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
ridnmyhonda
Mar 19, 2002 05:13 PM
ALF
Aug 16, 2001 05:47 PM
