93 prelude fuel problem
Old Aug 3, 2005 | 03:36 PM
gsrhatch87's Avatar
Default 93 prelude fuel problem
im doin an h22a swap into a 93 prelude and everything is done except for the fuel pump isnt turning on when you cycle the key over i was wondering if the reason for this was because of the PGM-FI main relay or if there was sumthing else that could cause this to happen please let me know as soon as possible id appreciate it thanks
Old Aug 3, 2005 | 03:40 PM
md23vtec's Avatar
Default Re: 93 prelude fuel problem (gsrhatch87)
Sounds like the main relay. Check the relay fuse first to make sure its good then check into the relay
Old Aug 3, 2005 | 05:24 PM
gsrhatch87's Avatar
Default Re: 93 prelude fuel problem (md23vtec)
where is the fuse for the main relay located? 93 prelude
Old Aug 3, 2005 | 05:49 PM
daveedd357's Avatar
double check the ground on the intake manifold or thermostat housing
Mr2u53
Mar 15, 2014 03:50 PM
pre93lude
Jun 22, 2008 12:12 PM
jamesjarvis85
Sep 12, 2007 05:39 AM
preludeChaos
Aug 7, 2001 08:58 PM
