does anyone know a place i can just get the coil overs springs?
i just want a set of 4 coil overs springs ...i mean just srpings not the perching part .....the reason why i'm asking bec i have some coil overs and the springs kept blowing my struts like every once a month and it comes down that my springs are not stiff like they should. i guess they are some cheap *** coil overs from ebay.
so let me know some set of stuff springs i can buy off from
http://www.ground-control-store.com for Eibach coilover springs.
What dampers are you using? You're probably blowing dampers because the springs are too stiff for the dampers to control them. You also could be riding too low, and bottoming out the dampers internally which damages them.
Don't go throwing money at a problem until you know exactly what is causing it.
