(Fan)In the front or behind radiator?
Old Aug 3, 2005 | 02:52 PM
allmotorhatch's Avatar
Default (Fan)In the front or behind radiator?
I have enough room to mount the fan in front of the radiator as well as behind. Is there any advantages or disadvantages either way.
Old Aug 3, 2005 | 09:55 PM
BoostedJeff's Avatar
Default Re: (Fan)In the front or behind radiator? (allmotorhatch)
dont know about cooling advantage, but it looks hella clean in front
Old Aug 3, 2005 | 10:24 PM
turtle-eg's Avatar
Put it behind the radiator... it's cools alot better as a puller fan.
Old Aug 4, 2005 | 06:11 PM
Turbocivic94's Avatar
I had it in front of the radiator then I put it behind the radiator. I think it works better behind it.
Old Aug 4, 2005 | 08:20 PM
dunkd's Avatar
how about both?
Old Aug 4, 2005 | 08:23 PM
SlowReaction's Avatar
Default Re: (dunkd)
I've put mine in front and in back, couldnt tell a difference.
Old Aug 5, 2005 | 03:55 AM
GreyPower's Avatar
It's usually between 8 - 10% more effecient behind. Regards
Old Aug 5, 2005 | 08:41 AM
CHEETAH's Avatar
I found a godo 5-10degrees cooler temps in our datalogs with it behind (vs in front).
we were close to the header and had to move to front, but it def ran cooler when behind, so if you have a choice, go behind.
greg
Old Aug 5, 2005 | 10:45 AM
Default Re: (Fan)In the front or behind radiator? (CHEETAH)
I ended up putting it behind the rad. Thanks for the replys guys
lsvtecEM1
Mar 19, 2012 05:18 AM
Herbie
Nov 6, 2006 02:38 PM
95LSS
Jul 24, 2006 06:35 PM
4doorH22
Jan 19, 2002 12:12 PM
