A/C problem
Old Aug 3, 2005 | 02:40 PM
Nah-Roo-Toe's Avatar
Default A/C problem
Hi guys/gals.
I went to a local shop to have my car serviced for the air conditioner. For some reason it just stopped being cold so I figured they would just pump freon and I'd be on my way.
Well after I got my car back it felt weird. As if the car was hesitating and the ac was nowhere near as cold as before. About a week later the a/c stopped being cold. I figured I had a leak so I didn't bother to think anything else. I bring it back and they pump it up again. The next day its not cold anymore.
I have my friend take a look at it and guess what? 90 % R-134 and 7.6 % R12!!!! How can that be?>?? Damn shop pumped my **** with R-134 instead of R12!! Any ideas on how this can be fixed? And does that mean my system is complete FUBAR'd?
BTW its a 93 DX coupe.
Old Aug 3, 2005 | 02:49 PM
jetpilot's Avatar
youll have to take out all of the gas, change the dryer filter and get it pumped again
Old Aug 3, 2005 | 02:50 PM
92HatchB16's Avatar
Default Re: A/C problem (Nah-Roo-Toe)
The two should definitely not be mixed. Go back to the shop with your receipt and tell them what they did. You are probably going to need to replace it. for that shop...
Old Aug 4, 2005 | 07:55 AM
Default Re: A/C problem (92HatchB16)
Yea i figured that much but the thing is my friend was telling me how Most shops wont vacuum it out because its contaminated and would ruin there system Is this true?
Old Aug 4, 2005 | 08:40 AM
integraXTC's Avatar
who gives a **** if it's true. They fucked it up, go see what can be done.
Old Aug 4, 2005 | 10:29 AM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nah-Roo-Toe &raquo;</TD></TR><TR><TD CLASS="quote">Yea i figured that much but the thing is my friend was telling me how Most shops wont vacuum it out because its contaminated and would ruin there system Is this true?</TD></TR></TABLE>
they are the ones that fucked up. tell them to vacuum out the system and put the right **** in there. I wouldn't care if they had to replace they're vacuum pump, it's their own damn fault to that shop
Old Aug 4, 2005 | 09:33 PM
revhard_si's Avatar
Vacum the a/c system n then replace it with R-12,run the car for atleast 3 miles n turn on the a/c after that the a/c will work if it doesnt that means that your a/c lost compression that means that it would only throw cold air when the car is running...good luck
Old Aug 4, 2005 | 11:04 PM
kkim's Avatar
I have my friend take a look at it and guess what? 90 % R-134 and 7.6 % R12!!!! </TD></TR></TABLE>
Just curious... how did your friend determine that?
Old Aug 5, 2005 | 01:26 AM
Stripped Honda's Avatar
99-0104
Default Re: A/C problem (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kkim &raquo;</TD></TR><TR><TD CLASS="quote">
Just curious... how did your friend determine that?</TD></TR></TABLE>
i would also like to know where he got these #'s .... because even if it was mixed it would still get cold
Old Aug 8, 2005 | 08:38 PM
revhard_si's Avatar
Give us an update... im just wondering
Old Aug 8, 2005 | 09:56 PM
nocturnaldragon's Avatar
When you mix the two like that it causes proplems with the oil, for some reason it turns it from a liqued to more of a gel like substance and clogs either the condesor or the evap. One of the two I forget which, its the one with the smaller passages and needs to be replaced along with some other misc parts. So have them vac it out asap and have them put the right stuff in there and who gives a **** about them? if there that worried pump the **** into a seperate container so it wont contaminate there stuff. Simple as that.
Old Aug 10, 2005 | 07:34 PM
revhard_si's Avatar
YEah thats pretty true...your last option is finding a damn new a/c from another car...
Old Aug 11, 2005 | 11:25 AM
Default Re: A/C problem (revhard_si)
Sorry I took so long to post. I've been really busy with work and school..name software builds
but anyway for the guys that asked me how i got the numbers. My friend attends UTI and took my car there. He was going to recharge the freon for me but wanted to run a few diagnostics first. About the shop, I finally have time this weekend so I'll let you know how that goes.
Old Aug 11, 2005 | 11:29 AM
kkim's Avatar
That still doesn't explain what he did to get those numbers. Really curious what was done to determine percentages of different gases in a system. Perhaps you could ask him what diagnostics he did?
Old Aug 11, 2005 | 12:41 PM
He said he hooked it up to a machine but yeah i'll find out how he did it and post up the results when i get the chance.
aneelmaan
Jun 9, 2014 07:22 PM
brevans4
12
Jun 20, 2011 01:04 PM
kelsarr
Jun 21, 2010 05:13 PM
FD3S
Feb 20, 2006 11:38 PM
vitaliy
Aug 15, 2003 10:53 AM
