Knocking/Rattling Noise from tranny
Old Aug 3, 2005 | 02:05 PM
LSVTEC 91 Civic's Avatar
Banned
Default Knocking/Rattling Noise from tranny
Okay, heres the deal. With the cluch engaged, there is a knocking/rattling noise coming from the transmission. With the clutch disengaged (Pedal out), the noise goes away.
Any ideas?
Old Aug 3, 2005 | 02:09 PM
91B16HF's Avatar
Default Re: Knocking/Rattling Noise from tranny (LSVTEC 91 Civic)
throw out bearing maybe, one of my buddies had the same problem but it would squeak instead of rattle.
Old Aug 3, 2005 | 02:20 PM
explictness's Avatar
i have the same problem, but mines rattled when it was not pedal being pushed off, then when i wreked my clutch to 100% it got worse. im reinstalling a new clutch now tho,
Old Aug 3, 2005 | 02:52 PM
Banned
bmup
Old Aug 4, 2005 | 03:15 AM
Banned
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">bmup </TD></TR></TABLE>
Old Aug 4, 2005 | 03:41 AM
Kaan's Avatar
Loved
Community Favorite
my throwout bearing did the same thing... just get a new clutch package... they usually come with a new throwout bearing.
Old Aug 4, 2005 | 05:35 AM
mahatma's Avatar
Default Re: (MMsportsRexSi)
One of the springs may have worked it's way loose or out altogether??
Old Aug 4, 2005 | 05:42 AM
mahatma's Avatar
Default Re: (mahatma)
^ Yeah the more I think about it the more sense that makes. Cause it would rattle around when you push the clutch in. Oh sorry I mean
Old Aug 4, 2005 | 06:33 AM
TheBobFather's Avatar
Throw out bearing..........had same problem
Old Aug 4, 2005 | 07:04 AM
W O T's Avatar
Default Re: (jnbhonda)
Had the exact problem and it would make a nice noise in the lower gears at slow speeds
Everyone on here said throwout bearing, I swapped it with a new unit and the problem didnt go away, took it to a shop and they said if I changed the TO bearing that it was the imput shaft, gave me a ridiculous quote so I just picked up another SI tranny for $125 and threw it in
Good luck though
Old Aug 4, 2005 | 08:15 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">^ Yeah the more I think about it the more sense that makes. Cause it would rattle around when you push the clutch in. Oh sorry I mean </TD></TR></TABLE>
What would rattle when I push the clutch in?
I've searched threads on throwout bearing failures, and from what I have read so far the people with bad throwout bearings expierence the rattle noise with the clutch disengaged, where I make noise with the clutch engaged.
This LS tranny was just put in the car about a month ago after I shot a hole through my old tranny, I'm running a Spec pressure plate and an ACT street/strip clutch.
Old Aug 4, 2005 | 08:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">One of the springs may have worked it's way loose or out altogether??</TD></TR></TABLE>
This could be it also. Imput shaft.............Take it apart and check it out
Old Aug 4, 2005 | 09:40 AM
mahatma's Avatar
I remember Kwicko (from the CRX resource, but same sn here) was helping me diagnose a different kind of tranny problem back in the day. He told me he had the same symptoms you're describing and it ended up being a clutch spring loose or broken. Maybe pm him for more details?
Seems like if that were the case, then you'd get all the rattling etc with the clutch pedal depressed since the clutch assembly would be separated from the flywheel, giving it room to get jiggy. Or does that not add up??
Old Aug 4, 2005 | 11:06 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">Seems like if that were the case, then you'd get all the rattling etc with the clutch pedal depressed since the clutch assembly would be separated from the flywheel, giving it room to get jiggy. Or does that not add up?? </TD></TR></TABLE>
It rattles with the clutch pedal pressed...
Old Sep 23, 2006 | 09:47 PM
baboonstyle's Avatar
update? what was the problem?
93S0L
Transmission & Drivetrain
Sep 14, 2008 03:52 PM
rdssk8rcs1
Jul 23, 2008 08:00 AM
Vt3c_eg
Apr 28, 2008 11:31 AM
slo_ej8
12
Apr 20, 2008 05:49 PM
jimbrown
Jul 17, 2007 12:35 PM
