quick question about compatibility, do crx tailights, pass side mirror, and fender fit the hatch???
Like the title said, going to the junkyard and they only have crx's. Do all those thing interchange with a 89 Civic std??? thanks AL
I went the other way, trying to install a side mirror from an '89 hatchback to an '89 Rex with no luck -- it mounts BUT you have very limited adjustability due to clearance issues for the mirror adjustment control peg. Can be solved with a little help from the dremmel (enlarge the hole for the control peg to pass through), but if you look around you should be able to find the proper hatchback parts (since there were so many more of those on the road).
mnmsddy
May 2, 2010 11:43 AM
sanjiyan69
Mar 16, 2006 04:44 AM
