RANDOM STUFF DC2 DC4 EG6 EH2 INTERIOR EXTERIOR PART OUT
EVERYTHING IS OBO, IF YOU ABSOLUTELY NEED A PIC. I CAN GET IT, BUT MOST OF THIS STUFF DOESNT NEED A PIC. AND IT IS ALL IN GOOD CONDITION.
JUST NEED THIS **** GONE, TAKING UP GARAGE AND BASEMENT SPACE
LOCATED NEAR CRYSTAL LAKE, ILLINOIS 60014
jdmf0r3v3r on aim - easiest way to reach me, always on.
Or just PM me
<FONT SIZE="4">INTEGRA PARTS!!</FONT>
INTERIOR
TRUNK/GAS POPPER - GREY
HOOD POP - BLACK
DOME LIGHT
DIMMER SWITCH
STEERING WHEEL WITH AIRBAG BLACK
LIGHT CONTROL STICK STALK by steering wheel CIVIC TOO
CRUISE CONTROL BOX
FRONT SEAT BOLT COVERS
REAR SEAT HOLDERS FOR THE TOP
SRS UNIT
DASH MOUNTS
DOOR LATCH FOR FRONT DOORS
DOOR LOCK CONTROL
REARVIEW MIRRORS SWITCH
PASSENGER AIRBAG - NO TOP COVER
DRIVERSIDE FRONT DOOR SPEAKER COVER
DOOR SILLS BLACK
HATCH PLASTIC FOR UNDER HATCH
ARMREST SCREW COVER BLACK
GLOVEBOX BLACK
ABS CONTROL UNIT
INTERIOR REAR VIEW MIRROR
DOOR SWITCHES FOR INTERIOR LIGHT
EXTERIOR
OEM 98-01 DRIVERS SIDE CORNER LIGHT
OEM 94-97 CORNER LIGHTS
PASSENGER SIDE HEADLIGHT 94-97
HOOD PROP
UNDERDASH FUSE BOX
UNDERHOOD FUSE BOX
REAR BUMPER HOLDER
CRUISE CONTROL THROTTLE CABLE
ABS UNIT
HUBCAPS 14"
GAS DOOR (frost white)
REAR DOOR MOULDINGS (frost white)
BRAKE BOOSTER
EVERYTHING FOR POWER STEERING
WINDSHIELD WIPER MOTOR
PUMP BRACKET
FRONT LCA'S
SHOCK FORKS
WINDSHIELD WIPER SPRAY RESERVOIR
FRONT BUMPER TOP METAL BY SCREWS
CRUISE CONTROL BOX/CABLE
FRONT BUMPER SUPPORT
WINDSHIELD WIPER ARMS
PASSENGER SIDE GSR FRONT KNUCKLE
ABS FUSE BOX
DC HOOD LATCH
CLUTCH RESERVOIR
A/C CANISTER
REAR SWAYBAR ENDLINKS
TOP HATS FOR SUSPENSION(4)
STOCK INTEGRA SPRINGS (LS/GSR)
ABS FUSE BOX (NO FUSES)
ABS FUSE BOX (ALL FUSES)
GSR/LS OEM springs
GSR OEM HEADER 94-99
GSR OEM HEADER 00-01
LS OEM HEADER 94-01
DC BRAKE BOOSTER
DC FRONT UPPER CONTROL ARMS
DC WINDSHIELD WIPER FLUID RESERVOIR
DC FRONT BUMPER SUPPORT
<FONT SIZE="4">CIVIC EG PARTS!!</FONT>
INTERIOR
HOOD POP - BLACK
GAS/TRUNK POPPER - GREY
EG TRUNK LIGHT
EG JDM COIN TRAY (A/C, SUNROOF, DIMMER BLOCK OFF)
EG LOWER BLOCK OFF PLATE UNDER COIN TRAY
EG HAZARD SWITCH
EG CLOCK BLOCK OFF
EG GUAGE CLUSTER SURROUND UNCUT
EG PASSENGER A PILLAR
EG DASH BOLT COVER FOR EACH END BLACK
EG LIGHT CONTROL SWITCH STALK
EG CLUSTER WITH BROKEN INDIGLOS NO TACH
EG GREY GLOVEBOX
EG UNDER DASH METAL
EG DOOR SWITCHES FOR DOME LIGHT
EG DASH MOUNTS
EG UNDER DASH AIR BLOWER
EXTERIOR
CLUTCH RESERVOIR
A/C CANISTER
EG STEERING RACK
EG UNDER DASH A/C CONDENSER
EG A/C LINES
EG RADIATOR MOUNTS
EG A/C MOUNTS
EG RADIATOR SUPPORT
EG FRONT BUMPER TOP METAL STRIP
EG A/C WIRING
EG OEM FUEL PUMP
EG FRONT WIPER MOTOR
EG BATTERY MOUNT W/ TRAY
EG THROTTLE CABLE
EG FENDER HOLDS
EG MASTER CYLINDER
EG CHARCOAL CANISTER
EG WINDSHIELD WIPER ARMS
EG UNDERHOOD COOLANT FLOW REGULATOR
EG UNDER HOOD FUSE BOX
EG UNDER DASH FUSE BOX
EG STEERING RACK
EG REAR HATCH HOLDER-UP CABLES
EG BRAKE BOOSTER AND HOSE
EG A/C PUMP
EG BATTERY GROUND
EG OEM FRONT TOW HOOKS
TOP HATS FOR SUSPENSION (4)
DX FRONT KNUCKLES/BRAKES (2 sets, one with extended lugs)
DX FRONT CALIPERS
EG BRAKE BOOSTER
EG MASTER CYLINDER
EG ROOF GUTTERS
EG FRONT UPPER CONTROL ARMS
EG FRONT LOWER CONTROL ARMS
EG FRONT FORKS
EG STEERING COLUMN PLASTIC SURROUND
EG REAR LCA (fits both sides)
EG A/C CONDENSER (mounts to front of car)
EG BRAKE BOOSTER
EG FUEL PUMP
EG REAR BUMPER SUPPORT
EG FRONT BUMPER SUPPORT
EG OEM INTAKE
EG WINDSHIELD WIPER FLUID RESERVOIR
DRIVERS SIDE DOOR HINGES
DRIVERS SIDE DOOR HOLDER OPENER
DRIVERS SIDE WINDOW REGULATOR
DRIVERS SIDE DOOR HANDLE
DOOR LATCHES
DOOR MOULDINGS FROM COMPLETE HATCH
<FONT SIZE="4">B-SERIES PARTS</FONT>
JDM GSR pistons w/ rods (rods need replacing i think)
LS A/C PUMP
LS FANS
LS OEM HEADER 94-01
LS OEM INTAKE ARM
LS SPARK PLUG WIRE HOLDER
<FONT SIZE="4">D-SERIES PARTS!</FONT>from a 1995 DX
A/C PUMP
ENGINE MOUNTS (all – manual)
Modified by midwesta at 6:11 PM 1/17/2006
Or just PM me
INTERIOR
HOOD POP - BLACK
DOME LIGHT
DIMMER SWITCH
CRUISE CONTROL BOX
SRS UNIT
DASH MOUNTS
DOOR LOCK CONTROL
DOOR SILLS BLACK
GLOVEBOX BLACK
ABS CONTROL UNIT
EXTERIOR
HOOD PROP
UNDERDASH FUSE BOX
UNDERHOOD FUSE BOX
REAR BUMPER HOLDER
ABS UNIT
HUBCAPS 14"
BRAKE BOOSTER
PUMP BRACKET
FRONT LCA'S
SHOCK FORKS
ABS FUSE BOX
DC HOOD LATCH
CLUTCH RESERVOIR
A/C CANISTER
GSR/LS OEM springs
LS OEM HEADER 94-01
DC BRAKE BOOSTER
INTERIOR
HOOD POP - BLACK
EG TRUNK LIGHT
EG HAZARD SWITCH
EG CLOCK BLOCK OFF
EG GREY GLOVEBOX
EG UNDER DASH METAL
EG DASH MOUNTS
EXTERIOR
CLUTCH RESERVOIR
A/C CANISTER
EG STEERING RACK
EG A/C LINES
EG RADIATOR MOUNTS
EG A/C MOUNTS
EG RADIATOR SUPPORT
EG A/C WIRING
EG OEM FUEL PUMP
EG THROTTLE CABLE
EG FENDER HOLDS
EG MASTER CYLINDER
EG STEERING RACK
EG A/C PUMP
EG BATTERY GROUND
DX FRONT CALIPERS
EG BRAKE BOOSTER
EG MASTER CYLINDER
EG ROOF GUTTERS
EG FRONT FORKS
EG BRAKE BOOSTER
EG FUEL PUMP
EG OEM INTAKE
DOOR LATCHES
LS A/C PUMP
LS FANS
LS OEM HEADER 94-01
LS OEM INTAKE ARM
A/C PUMP
