90-93 integra axles in a 99si trans?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">Im almost 100% sure the axles will not work
</TD></TR></TABLE>then why am I using 00si axels in my cable s1 tranny?
i beleive u just have to have the corresponding intermediate shaft on the driver side, correct? Like hydro interm. shaft with hydro axle, vice versa? i dont think passenger side would matter....not sure though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote">i beleive u just have to have the corresponding intermediate shaft on the driver side, correct? Like hydro interm. shaft with hydro axle, vice versa? i dont think passenger side would matter....not sure though.</TD></TR></TABLE>
exactly
use integra 90-93 midshaft and everything will worl
exactly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g24jr »</TD></TR><TR><TD CLASS="quote">there are two intermediate shafts?</TD></TR></TABLE> hydro and cable
kinda the same situation im going through now! it says to use 90-93 axles for a 88-91 b16a swap cable trans. but i got 94- up axles which im trying to figure out if they will work .. the guy i bought them from said they will there just newer unlike 90-93 used
the older teg intershaft has a female(in)end and the newer tegs have a male end (out). So this makes the drivers side shaft opposite from older to newer as one slips in and one slips over.
newer = over http://cgi.ebay.com/ebaymotors...ZWDVW
older = slips inside http://cgi.ebay.com/ebaymotors...ZWDVW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 »</TD></TR><TR><TD CLASS="quote"> i will be using 90-93 axles with 90-93 intermediate shaft.. so this will work in a 99 b16 trans?</TD></TR></TABLE>
Yes, you will just need the axle seal for tranny on the driver side b/c the axle seal on the hydro tranny has a smaller opening (35mm) and the SK7 Intermediate shaft (DA i-shaft) requires a 40 mm opening.
Just call up Honda (b/c the seal can also be found on 5 sp civics) or acura and ask for this part number 91205-PL3-B01 OIL SEAL (40X56X8
I think its like $10-$15.
You can pop out the old seal with a screwdriver and then just tap the new one flush with a hammer.
Good luck
Good luck
