need help- clutch issues
91 accord
new clutch install with lightened flywheel
used alignment tool
the tranny mated flush
clutch master cylinder and slave are good
there are no leaks
slave is moving and fork moves
new throw out bearing
Bleed the line/no air left at all
PROBLEM
Clutch will not disengage. You push on the clutch pedal and the damn clutch remains connected. I'm pretty good about this $hit but this thing is giving me a headache. Any thoughts?
used alignment tool
there are no leaks
PROBLEM
mmm if pedal feels normal meaning does not drop to floor like it has air in sytem could be pressure plate or clutch bearing was not installed properly thus not pushing fingers on pressure plate
I've seen this sort of problem when a throwout bearing and pressure plate are mismatched; the throwout bearing jams into the pressure plate, and locks the clutch.
