turn signal wont automatically turn off anymore after momo wheel isntall
Old Aug 2, 2005 | 07:43 PM
TrueUntilDeath.com's Avatar
Default turn signal wont automatically turn off anymore after momo wheel isntall
i installed a momo hub w/ a monte carlo
and now when i signal and then make a left or right turn, the signal indicator will not turn off on its own anymore.
anyone know why?
Old Aug 2, 2005 | 08:06 PM
. a d a m's Avatar
Default Re: turn signal wont automatically turn off anymore after momo wheel isntall (Loveless @ ImportERA)
Did you make sure you replaced all the parts that indicate the position of the steering wheel properly so that it knows when to turn your signals off?
I'm not to good with problems like this but this seems to be the most logical answer to me.
Old Aug 2, 2005 | 08:09 PM
Racermech's Avatar
Default Re: turn signal wont automatically turn off anymore after momo wheel isntall (Sh!ttyLS)
use the search, there is a thread either here or in the ITR forum about this, and how to fix it. It involves using a washer or tow to push the little switch futher in so the will turn off.
Old Aug 3, 2005 | 09:18 AM
Default Re: turn signal wont automatically turn off anymore after momo wheel isntall (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">use the search, there is a thread either here or in the ITR forum about this, and how to fix it. It involves using a washer or tow to push the little switch futher in so the will turn off.</TD></TR></TABLE>
cant find anything, what do i search it under?
i tried:
turn signal steering
momo signal
aftermarket wheel turn signal
Old Aug 3, 2005 | 09:31 AM
SMZ GSR's Avatar
Is it that much work to put out your middle finger to flick it off? lol
Default Re: turn signal wont automatically turn off anymore after momo wheel isntall (SMZ GSR)
yes it is.
Old Aug 3, 2005 | 10:10 AM
Finger Lickin' good's Avatar
i have a similar problem. Installed a jdm itr srs, when I turn right(pushing indicator stick "up"), it never turns off. However, 1 of the 2 dowel pins that stick out from the steering column/abs sensor broke...
Did anyone have to break those off to install a new wheel? Maybe this is the culprit.
luciffer
Sep 13, 2008 09:11 PM
russianswty
Mar 5, 2007 10:27 AM
blackeg
17
Feb 19, 2007 05:01 PM
Larkin W.
Dec 1, 2006 06:14 AM
hondaracing1
Aug 7, 2004 10:55 PM
