How to wire chipped ECU 1 wire VTEC?
Old Aug 2, 2005 | 07:40 PM
shbrown's Avatar
Default How to wire chipped ECU 1 wire VTEC?
I have a chipped PM6 with Z6 maps and VTEC output on the A/T lockup. I need help with the physical wiring from ECU to solenoid. It looks like I need a crimp pin to add to the ECU plug, a wire from there to solenoid, and a plug to mate with the solenoid. The wire is easy, but where can I find the crimp pin and solenoid plug? Any hints on a way through the firewall? Or is there an easier way?
summary: where can I get ECU crimp pin and VTEC solenoid plug? Or easier way?
Old Aug 2, 2005 | 07:50 PM
Fobtions's Avatar
Default Re: How to wire chipped ECU 1 wire VTEC? (shbrown)
u need to get a spare ecu pin off a car.
check the location on your car it might already have the pin in there.
i see you are in sd , i have extra pins.
Old Aug 2, 2005 | 08:00 PM
shbrown's Avatar
Checked my harness, couldn't see any empty pins. Anyone know if there is an empty pin on a stock 89 CRX Si harness?
Fobtions, where are you located? Thanks!
-S
Old Aug 3, 2005 | 12:10 AM
michael O's Avatar
Default Re: (shbrown)
I think for the solenoid plug I just found some plug at the junkyard and repinned that.
Old Aug 11, 2005 | 04:51 PM
shbrown's Avatar
Anyone know of any CRX's left in SD junkyards? (That might still have wiring) I have been tring to get a hold of fobtions, but no luck. I am getting antsy about getting vtec plugged in.
Thanks!
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
pnwjdm
Jan 12, 2013 05:34 AM
ilovemyb16a
May 18, 2006 12:58 PM
Monkey Fing a Coconut
May 28, 2005 06:58 PM
JDM CRX
Mar 25, 2002 08:01 AM
