cam problems in gsr
Old Aug 2, 2005 | 07:25 PM
CivicExTurbo's Avatar
Default cam problems in gsr
I am in the process of swapping my B16 out and putting in my gsr. One of the cams takes 50 pounds of torque to turn and other takes 30 pounds. We loosen the bolts on the head and it still is very hard to turn. We took off the cam and seems to be just fine. What is there to do? Please help!
Old Aug 2, 2005 | 07:36 PM
95 integra's Avatar
Default Re: cam problems in gsr (CivicExTurbo)
The intake cam has bigger lobes, thus it is harder to turn.
Old Aug 3, 2005 | 08:15 AM
Default Re: cam problems in gsr (95 integra)
so theres nothing wrong with it?
Old Aug 3, 2005 | 08:20 AM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">The intake cam has bigger lobes, thus it is harder to turn.</TD></TR></TABLE>Plus double springs, so a higher spring rate.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicExTurbo &raquo;</TD></TR><TR><TD CLASS="quote">so theres nothing wrong with it?</TD></TR></TABLE>Sounds OK to me.
Old Aug 3, 2005 | 08:52 AM
The timing belt wouldnt turn it though.. Is 50 pounds of torque to much?
Old Aug 3, 2005 | 05:06 PM
95 integra's Avatar
There's more then one thing that can hold a timing belt from spinning...........such as rusted sleeves that dont allow the pistons to move. Im going to say as long as the cams have the normal "kick back" where its hard to turn and then sorta kicks itself around after the hardest part, then 50 ft/lbs is fine. I know Ive broken my cam bolts loose trying to get the cam gears lined up at TDC and they are torqued at 33 if Im not mistaken, so 50 sounds about right to me.
Old Aug 3, 2005 | 11:52 PM
Ok well the engine is built and it has GE sleeves 84.5 so guess everything should be fine. Ill see what happens. Thanks
tapboyzlilj
Feb 5, 2008 11:50 AM
crazyguy
Jan 30, 2008 07:52 AM
NA JDM GSR
Nov 27, 2006 03:16 PM
milano2kdc2
14
May 13, 2005 06:34 PM
integmester
Apr 18, 2005 12:34 PM
