Highest safest redline on GSR
Old Aug 2, 2005 | 06:58 PM
BLK99VTECR's Avatar
Default Highest safest redline on GSR
whats the highest safest redline I can go up to on a stock block GSR. My car is in the shop now to get some head work and the shop recormended me getting their valve train(titanium retainers and springs). I know this will allow the head to take a beyond stock rev limit shift, but what will my bottem end be able to handle safely. I am very hard set on not damaging my motor after I get it back because im pushing my budget as it is just to get the work done now and throwing a rod or somthing cause of to high of a shift is the last thing i need. Also what could be another advantage of having titanium valve springs and retainers?
Old Aug 2, 2005 | 07:12 PM
stewmaster-k's Avatar
Default Re: Highest safest redline on GSR (BLK99VTECR)
i found a site that says 8200 RPM ; heres the link: http://www.jazzproparts.com/Pr...Specs
Old Aug 2, 2005 | 07:14 PM
daLixz25's Avatar
Drop some money on the block while they have the head off!
Old Aug 2, 2005 | 07:45 PM
. a d a m's Avatar
Default Re: Highest safest redline on GSR (stewmasterk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stewmasterk &raquo;</TD></TR><TR><TD CLASS="quote">i found a site that says 8200 RPM ; heres the link: http://www.jazzproparts.com/Pr...Specs</TD></TR></TABLE>
That's correct. The stock GSR has a rev limit of 8200 rpm.
Old Aug 2, 2005 | 08:06 PM
Tweakmeister's Avatar
Take it to the moon if you want -
As a famous engine builder on here once said, "RPM = Ruins People's Motors"
The higher you go, the more wear it will have. If you plan on a rebuild down the line, then take it higher - but only if it makes power there (I doubt it will, but let us know your cams).
Old Aug 2, 2005 | 08:15 PM
BLK99VTECR's Avatar
Default Re: Highest safest redline on GSR (Tweakmeister)
well right now im just doing a drop in of a CTR intake cam wit GSR exhuast cam, so I know a higher redline aint gonna help that. If im not satisfied wit what i get wit that set up I can go wit some skunks. I just wanna know what a stronger valvtrain can do for a motor besides allow it to rev higher, and what will my stock bottem end be able to handle with no problems when i install hondata and can set a redline.
Old Aug 3, 2005 | 02:48 PM
BLK99VTECR's Avatar
looks like 8500 is the safest point. im trying to see if i can get a deal on Some skunk stage 2s
soon2bdropped
Sep 11, 2007 06:07 PM
aznegg
Mar 5, 2007 05:49 PM
BLK99VTECR
25
Aug 4, 2005 02:33 PM
BLK99VTECR
10
Aug 4, 2005 08:42 AM
slowsleeper
12
Sep 18, 2004 03:30 PM
