b16 build up
ok guys, having some issues. the guy doing my b16 bored it to 81.5 instead of 81.25. now i cant use ctr pistons or p30s. the only reason its torn back down is cause of a spun bearing due to using topline crap. so now the question is what piston company should i go with? i am wanting it all motor, and preferably no higher than 11.5:1 comp. more towards 11:1 comp. not sure what company to use. hear good and bad about wiseco. je and srp and cp are options, opinions on arias and all the above are appreciated. and also what cams to run with the setup. please help soon so i can get my motor back and running, i miss her.
thanx for your ideas, kinda wanting to stay away from skunk2, heard there cam lobes wear down the quickest. umm also this is also all gonna be in an 89 civic hb and im still obd0, not sure if this affects the type of engine management. or if i can run one unless i switch over. thanx for all the help tho.
