Already search..Cel 4 on B18b swap..HELP
Old Aug 2, 2005 | 06:26 PM
camboMONK's Avatar
Default Already search..Cel 4 on B18b swap..HELP
OK this is a last resort after countlless hours of searching and trying to diagnose the issue. Here's the situation.
92 B18b swap into a 90 si HB
ECU-PR4 running OBD0
Dizzy-90 LS
At first , the car would not hold idle after it is started. Car would simply stutter at 200 rpm and if we gave some gas it would die. threw a cel 4 and cel 14. We cleaned the EACV and replaced the dizzy. Now the car starts and idle @ 1k rpm and Cel 14 went away but cel 4 is still glowing. The car would not rev past 3k rpm. Im lost at this point. Please HELP!!!
Old Aug 2, 2005 | 07:32 PM
camboMONK's Avatar
Default Re: Already search..Cel 4 on B18b swap..HELP (camboMONK)
BUMP....Please help
Old Aug 2, 2005 | 07:45 PM
Skinflute22's Avatar
i think code 4 is the crankshaft position. make sure your timing is right
Old Aug 2, 2005 | 08:26 PM
camboMONK's Avatar
Default Re: (Skinflute22)
Thanks...timing is perfect. Anything else I should check?
Old Aug 3, 2005 | 01:21 PM
camboMONK's Avatar
Default Re: (camboMONK)
Somebody. Anybody. Please help.
Darkane
Jun 16, 2008 08:41 PM
swappedcx
Feb 16, 2006 10:38 PM
Skip01
Oct 17, 2005 10:37 AM
TylerC
Aug 18, 2005 10:28 PM
