Adjustable front /rear twin master cylinder setup info need
Old Aug 2, 2005 | 04:57 PM
Garrett's Avatar
Default Adjustable front /rear twin master cylinder setup info need
I have seen it on a M3 race car with a twin master cylinder that could adjust front and rear brake ratio from cockpit
and I want to know which company made parts like that
thanks for the help
Old Aug 2, 2005 | 09:45 PM
krazie1's Avatar
BANNED
Default Re: Adjustable front /rear twin master cylinder setup info need (Garrett)
why???
it would do any good for us HONDAS
Old Aug 2, 2005 | 10:31 PM
burnout289's Avatar
couldn't you just use an adjustable valve like the one from Wilwood? Summit Racing sells those fairly cheap.
Old Aug 3, 2005 | 01:02 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Adjustable front /rear twin master cylinder setup info need (burnout289)
You can use the Wilwood one, but you obvisouly have to make a lot of custom lines.
Old Aug 3, 2005 | 03:28 AM
Garrett's Avatar
Default Re: Adjustable front /rear twin master cylinder setup info need (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">You can use the Wilwood one, but you obvisouly have to make a lot of custom lines. </TD></TR></TABLE>
yes I could
but 2 master have more adjsutement than proportionning valve
I find it
http://www.tiltonracing.com/co...5&m=b
http://www.tiltonracing.com/co...2&m=b
Old Aug 3, 2005 | 06:12 AM
drdisco69's Avatar
You ain't seen custom lines until you've seen a dual master cylinder setup on car that didn't come with it. Nice avatar, btw.
All I have to say is that if you really want all this, it better be a race car and you better be fast. You'll need the pedal assembly, two master cylinders, the adjuster bar, and if you want to adjust from the seat, that cable you found as well. You're going to lose power assist, and you're going to have to find a way to mount it. Then you're going to have to run your lines inside the car to the master cylinders. Now you have one line for front and one line for rear, but your car isn't set up that way. Hondas have a diagonally split braking system, so you're going to have to make a distribution block and reroute all the lines by the proportioning valve.
My friend did something similar, and he wound up running new lines all over the car. I hope it's worth it.
Old Aug 3, 2005 | 08:03 AM
Garrett's Avatar
Default Re: Adjustable front /rear twin master cylinder setup info need (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
My friend did something similar, and he wound up running new lines all over the car. I hope it's worth it.</TD></TR></TABLE>
Exactly
IT's a race car
with all around braided SS lines
front master to each wheels
krazyhmongboi
Jul 10, 2008 08:40 PM
herde1724
Aug 11, 2005 11:37 AM
Footwork
13
Feb 11, 2005 06:58 PM
blackccoupe
Sep 14, 2003 07:23 PM
