P8R B20Z got tuned today, not all that impressed
Old Aug 2, 2005 | 01:39 PM
BigC-ivic's Avatar
Default P8R B20Z got tuned today, not all that impressed
I'm not really that impressed. The increase is good, but the overall power sucks.
I have a b20Z with a P8R head (33mm intake valves), Crower 403's and upgraded valvetrain, Comptech header, Thermal 2.25 exhaust, AEM CAI, Skunk2 IM
The redline was raised to 7500
Here are some pics:
What do you guys think?
Old Aug 2, 2005 | 01:43 PM
RobbieG35's Avatar
12 Years Strong
Default Re: P8R B20Z got tuned today, not all that impressed (BigC-ivic)
I don't see how the hell a B20 can only have 109 torque What type of dyno is this on?
Old Aug 2, 2005 | 01:51 PM
BigC-ivic's Avatar
Default Re: P8R B20Z got tuned today, not all that impressed (HybridHatch88)
Mustang Dyno
Old Aug 2, 2005 | 01:59 PM
Hapexamendios's Avatar
torque seems way low
Old Aug 2, 2005 | 02:22 PM
GUILOTINE's Avatar
Kill Gil
numbers from Mustang dyno's are hard to compare to DynaPack, Dyno Dynamics, or Dynojet numbers. Why not just pay for a base line on a different Dyno?
Old Aug 2, 2005 | 02:31 PM
Fkned's Avatar
Was the p8r head already on the motor before or did you just add it?I have never seen a p8r head in person and don't know the chamber's cc size but I would think it's bigger them the regular ls heads that have an 81mm bore chamber vs your 84 mm bore chamber.You may have lowered the compression to the point it hurt power esp torque.
Old Aug 2, 2005 | 02:37 PM
lohatch's Avatar
yah something isnt right with the setup because i made 105tq on a mustang dyno with a D16. i would think with that 2.0 block you would be seeing much better TQ numbers at least.
Old Aug 2, 2005 | 08:04 PM
hybrid_vtec's Avatar
Default Re: P8R B20Z got tuned today, not all that impressed (lohatch)
Torqur does seem low. However your power doesnt look bad for 403's and no raise in compression. Bump up the compression and you should see gains. Also 404's make way more power than 403's.
The P8R heads have a 47cc combustion chamber as to to the normal head is 45cc.
Seriously if you think about it you are at 8.8:1 CR right now, so if you bump it up to 11.0:1 + and add 404's you will see big gains! You have bigger Intake valves, take advantage of them.
Old Aug 2, 2005 | 08:22 PM
xEnderx's Avatar
Default Re: P8R B20Z got tuned today, not all that impressed (hybrid_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Torqur does seem low. However your power doesnt look bad for 403's and no raise in compression. Bump up the compression and you should see gains. Also 404's make way more power than 403's.
Seriously if you think about it you are at 8.8:1 CR right now, so if you bump it up to 11.0:1 + and add 404's you will see big gains! You have bigger Intake valves, take advantage of them.</TD></TR></TABLE>
ONce again the nonvtec guru speaks.
Old Aug 2, 2005 | 09:36 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec &raquo;</TD></TR><TR><TD CLASS="quote">The P8R heads have a 47cc combustion chamber as to to the normal head is 45cc.</TD></TR></TABLE>Ahh I see,thank you that rules my theory out.
Old Aug 13, 2005 | 01:54 PM
BigC-ivic's Avatar
Default Re: P8R B20Z got tuned today, not all that impressed (Ed's Racing Heads)
so I took it to the track today and ran a 15.325 at 90.197 mph
compared to a 15.268 I ran before the new head, Crower 403s and tuning
the only good news is that I am more consistently running 15.3s
The mph are a little higher than normal (which shows potential)
Bad news: I can't get my 60ft times any lower than 2.2, I think its just the camber problem
Old Aug 13, 2005 | 05:25 PM
Mag00n's Avatar
How do you expect those allmotor cams to make ANY kind of power with an 8:8 c/r? Bump the c/r and you will see NICE gains.
Old Aug 13, 2005 | 05:53 PM
duh naNG's Avatar
Default Re: P8R B20Z got tuned today, not all that impressed (Mag00n)
i agree you need more compression to see the gains you are looking for
Old Aug 13, 2005 | 06:12 PM
RudeBwaiSi's Avatar
I share the same sentiment, CR too low.
Old Aug 13, 2005 | 08:06 PM
The Destroyer's Avatar
I thought the B20Z had higher comp that 8.8?
Old Aug 13, 2005 | 09:42 PM
RagingAngel's Avatar
Seriously if you think about it you are at 8.8:1 CR right now....</TD></TR></TABLE>
Bigger combustion chamber drops CR.
Old Aug 14, 2005 | 07:10 AM
Default Re: P8R B20Z got tuned today, not all that impressed (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
I am aware of this, but is 2cc that much of a comp drop?
Old Aug 14, 2005 | 08:36 AM
Default Re: P8R B20Z got tuned today, not all that impressed (Vtaaak y0)
you're right...
it should still be about 9.3:1 ish with the B20Z pistons and a OEM 3 layer gasket. vs. 9.6:1 on the 45cc chamber.
Irregardless, it's still pretty low for a performance cam.... it should at the very least be 10:1....
Old Aug 14, 2005 | 08:46 AM
Mag00n's Avatar
If you think about it, JDM B16'S are 10.2-10.4 depending on which generation were talking. And even with 10.4, your still not getting all the power you COULD get out of stage1 cams or even typeR cams.
I know were not talking about a vtec motor but the concept is the same. Aggressive cams need high compression to maximize performance gains.
Old Aug 14, 2005 | 11:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">
I thought the B20Z had higher comp that 8.8? </TD></TR></TABLE>
You're right, B20Z is 9.6:1. My bad!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">If you think about it, JDM B16'S are 10.2-10.4 depending on which generation were talking. And even with 10.4, your still not getting all the power you COULD get out of stage1 cams or even typeR cams.
I know were not talking about a vtec motor but the concept is the same. Aggressive cams need high compression to maximize performance gains.</TD></TR></TABLE>
You can only go so high with compression until it begins to hurt your performance and gains become minimal. Also it will put tons of stress on the motor b/c it will be working against the compression and cause the motor to be less reliable.
If it is for the street, choose something reasonable that will match the cam. Calculate for Dynamic Compression Ratio rather than static. This way you will know your real CR for the setup you choose to run
Old Aug 14, 2005 | 11:25 AM
spock_rocker's Avatar
memoryFAB.com representative
before i put my 404s in i plan on raising the compression... you ran a 15.2? i ran a 15.1 with a stock B20Z in my hatch.. i hope my 404s ran better than that.
Old Aug 14, 2005 | 11:49 AM
noboostedEGo's Avatar
Default Re: P8R B20Z got tuned today, not all that impressed (spock_rocker)
If it is for the street, choose something reasonable that will match the cam. Calculate for Dynamic Compression Ratio rather than static. This way you will know your real CR for the setup you choose to run</TD></TR></TABLE>
How do you calculate for dynamic compression ratio? Yeah I searched, any links?
Old Aug 14, 2005 | 12:08 PM
Default Re: P8R B20Z got tuned today, not all that impressed (noboostedEGo)
http://www.rbracing-rsr.com/comprAdvHD.htm
Old Aug 14, 2005 | 12:24 PM
Mag00n's Avatar
Im aware of that, i never told him to go crazy, i told him that 8.8 or 9.3 or whatever the hell hes running is not enough to match his cam choice.....
Dont forget tuning too...
Old Aug 14, 2005 | 02:50 PM
Dont forget tuning too...</TD></TR></TABLE>
I think 11.4:1 Pistons Endyne offers would be great for him.
