Can't Get Valve Cover OFF!!!!!!!
Old Aug 2, 2005 | 11:16 AM
Geeq's Avatar
Default Can't Get Valve Cover OFF!!!!!!!
OK. Went to Loosen the valve cover bolt and ran into a problem. The bottom left one doesn't want to come off. It wasn't very tight either.
But It just spins. And won't tighten again or Come off.......What do I do now??
Motor H22a4
Top three bolts came off fine and the lower right. Just the left lower bolt just spins.
What to do?????
Old Aug 2, 2005 | 12:43 PM
TheAntiRice225's Avatar
Default Re: Can't Get Valve Cover OFF!!!!!!! (Geeq)
Try taking a pair of plyers and prying up on the bolt (just a little. Don't pry it out) while you loosen it.
I hope that helps. ...
Old Aug 2, 2005 | 07:15 PM
PrettyLude's Avatar
its stripped, best thing i can say to do is shoot it off with an airratchet
Old Aug 3, 2005 | 02:46 AM
D Grade's Avatar
Default Re: (PrettyLude)
Is all else fails, use an easy out or drill into the bolt enough to get a broken stud remover in there.
I'd recommend stopping by the dealership and picking up a new stud on the way to putting that VC back on.
SlowB16si
Jan 28, 2006 02:13 PM
renzema
Aug 29, 2005 09:42 AM
hondaracin24
May 10, 2005 04:38 PM
jdmsijdm
May 11, 2004 07:31 AM
VR6T
Mar 6, 2003 04:22 AM
