d16y8 into 88 crx hf?
Old Aug 2, 2005 | 11:11 AM
pfiaccord's Avatar
Default d16y8 into 88 crx hf?
I was wondering if i could put a d16y8 from a 99 civic ex into my 88 crx hf.
if so what will i need to complete the swap,axles, wiring harness or conversion,different trans, etc. thanks for any help
Old Aug 2, 2005 | 12:32 PM
teknohatchie91's Avatar
Default Re: d16y8 into 88 crx hf? (seearex)
u would need to convert to odb1 or 2, along with getting the right ecu, its pretty easy, rywire.com can help u with that, you can maintain ur tranny and axles but hf tranny's gears suck, so might as well get an si tranny while your at it. good luck
Old Aug 2, 2005 | 01:03 PM
menappi's Avatar
Default Re: d16y8 into 88 crx hf? (Jerren)
i know on the back of the y8 there is only one sensor type thing (not sure of the name, i think its either the thermoswitch or thermosensor) but on the back of the a6 block theres two (one with two prongs and one with one), im wondering what do u do about that? the reason why i ask is because i converted my 88si to obd1 planning on doing a mini me, but instead im getting a z6 swap and im putting that in, and i know the same holds true to that motor too, about missing one sensor, so what do i do. im using p28, so i just leave it unplugged. ?
Old Aug 2, 2005 | 08:36 PM
d16vtecx's Avatar
Default Re: d16y8 into 88 crx hf? (menappi)
the 2 prong thingy is the thermosensor and they moved it to the thermostat housing for obd 1
koolme88
23
Oct 6, 2011 12:46 PM
mugen Dan88
Aug 23, 2010 08:15 AM
pfiaccord
Aug 2, 2005 12:49 PM
pfiaccord
May 30, 2005 08:35 PM
mt23vtecbb2
12
Feb 9, 2004 06:57 PM
