Having problems starting my 1997 Prelude after 1+ days of not driving?? System running lean? Full in
Old Aug 2, 2005 | 10:59 AM
Johnny916's Avatar
Default Having problems starting my 1997 Prelude after 1+ days of not driving?? System running lean? Full in
I have a 1997 Prelude with an Auto Trans. It has 92K miles and I just had the distributor changed because some dorky mechanic thought it was not starting sometimes because of the distrib.
As it turns out, it's not the distributor because I'm still having the same problem!
After a day or two of not driving the car will crank but won't start. It almost starts but doesn't!
But wait! After I take the spark plugs out, clean them, and put them back in about half an hour later the car starts does up?
The latest mechanic to check out my car out told me the car was running LEAN, he put it on the smog tester. But he was the same mechanic to tell me it was the distributor!? Anyways, he said the remedy would be to have the full injectors cleaned, should I go ahead with this or do you guys think it something else?
Old Aug 5, 2005 | 11:41 AM
Johnny916's Avatar
Default ATTENTION SUPER TECHS! Re: Having problems starting my 1997 Prelude after 1+ days of not driving?? S
Can somebody read this and tell me if the fuel injectors need to be cleaned?? Or are leaking?
By the way, when I do take the plugs out I do see fuel on them and I do hear the fuel pump.
Modified by Johnny916 at 12:58 PM 8/5/2005
Old Aug 5, 2005 | 06:37 PM
onefastrx7turbo's Avatar
Default Re: ATTENTION SUPER TECHS! Re: Having problems starting my 1997 Prelude after 1+ days of not driving
sounds like you may be fouling out plugs? it cranks but doesnt start? almost starts? sounds like plugs or maybe a fuel pressure problem.
Old Aug 5, 2005 | 11:00 PM
Johnny916's Avatar
What does fouling the spark plugs mean?
HondaLude93
Sep 21, 2007 04:24 AM
oneprelude
Sep 3, 2007 10:12 PM
turbob18si
Dec 20, 2006 02:33 PM
94preludeguy
Sep 11, 2006 04:18 PM
13BT
Feb 4, 2004 07:06 AM
