need help with last minute prep on b16 swap
Old Feb 20, 2002 | 05:45 AM
brian.edge's Avatar
Default need help with last minute prep on b16 swap
i still have my 91si and next week i am planning on going and picking up my motor for my swap.., now my question is what small parts should i get that i might have not thought about, do i need a new throttle and clutch cable? radiator hoses?....... right now i am cocerned about hte small parts so i know i have all of them....any help is appericated
Old Feb 20, 2002 | 06:01 AM
EP3_05's Avatar
Default Re: need help with last minute prep on b16 swap (lilhibbs)
91 integra lower radiator hose
91 integra throttle cable
92 gsr upper radiator hose
94 Del Sol VTEC water pump and timing belt
91 integra cap and rotor
Make sure your motor comes with the rear motor mount bracket, intermediate shaft and axles. If not you will need to source them off of a 90-93 integra.
Hope this helps
Old Feb 20, 2002 | 06:11 AM
sleeper4dr's Avatar
Default Re: need help with last minute prep on b16 swap (91civic)
i would also think about swapping the clutch while you have the motor out. at the LEAST, you could get a 90-91 integra clutch disk just so you know you have a new clutch in there. maybe replace the throw-out bearing while you're at it also.
might want to also replace the Timing Belt if you're doing the water pump. a 94 Del Sol VTEC belt or 99+ Si belt would work.
Old Feb 20, 2002 | 06:12 AM
TypeR0207's Avatar
Default Re: need help with last minute prep on b16 swap (sleeper4dr)
Check it out, the search function is your friend ...... (and this was only a few days ago):
https://honda-tech.com/zerothread?id=131164
Old Feb 20, 2002 | 06:31 AM
brian.edge's Avatar
what clutch would you guys suggest?
Old Feb 20, 2002 | 08:08 AM
EL Vap133's Avatar
ACT !!!
Old Feb 20, 2002 | 12:19 PM
SpooN Man's Avatar
Default Re: need help with last minute prep on b16 swap (Vap133)
exedy, I just got mine the other day. 287 shipped with everything.
Try ClutchCityOnline.com
Old Feb 20, 2002 | 12:40 PM
raph's Avatar
how much would all this cost? im gonna do my swap soon so i just want to know how much more money i will need.
Eduardo_95
Sep 13, 2015 11:41 AM
ef9robert
17
Feb 24, 2006 05:52 AM
scul8r1990
May 19, 2005 01:06 PM
soon2b
Jan 15, 2004 04:43 AM
JDMVTEC
Oct 30, 2003 07:26 PM
