k-series motor
Old Aug 2, 2005 | 09:11 AM
ALLMOTORD16Z6's Avatar
Default k-series motor
Which is the better k-series to swap to and where can you get them.
Old Aug 2, 2005 | 09:23 AM
k-series's Avatar
Default Re: k-series motor (ALLMOTORD16Z6)
Not to beat a dead horse here, but try searching.
What do you want to build (all motor, N20, turbo, etc..)? What's your HP range/goal?
There are a lot of choices so you need to give as much info as possible.
Steve
Old Aug 2, 2005 | 10:15 AM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: k-series motor (k-series)
why not dead horse's are fun to beat. they have a certain smell about them. way better then live ones they tend to fight back.
Old Aug 2, 2005 | 11:23 AM
SpeedDreamz.com's Avatar
Default Re: k-series motor (duckmanEG)
K20a or A2 are the best to go with. Or the k24 block with k20a/a2 head. Stay away from the a3
Old Aug 2, 2005 | 12:21 PM
I want to run all motor, in my 93 hatch. I want as much HP as i can get for a good price. My goal is 300whp but i know that is prob going to cost me since it is a K motor. What is realistic for the K motor (all motor) street car.
Old Aug 2, 2005 | 12:56 PM
duckmanEG's Avatar
Sexy Cheese Cake
300 is realistic with lots of money. anywho if u going to pick a engine if u can find a tsx longblock engine get that, it has the same if not better head then the k20a2, but if not u get a k24a(1,3,4) to build then for sure get the k20a2 head.
plus if u plan on runnign sum kind of custom rod/crank or sumthing the k24's are better since they have a taller deck.
k-series's Avatar
Street car? Easy, K20A2.
Mods for a street car (only about 25whp):
ITR Manifold
IPS K2 Cams
Upgraded Valvetrain
Hondata K-Pro
Race Header
New Exhaust
etc...
Steve
Old Aug 2, 2005 | 01:47 PM
duckmanEG's Avatar
Sexy Cheese Cake
i would for sure agree with the k20a2 for a D/D then weekend warrior. they can be pick up rather cheap. if ur looking for mounts u can check http://www.speedshoponline.com . they have awesome deals from what i have seen and good customer service also hybirdracing has good conversion harness u might want to look into.
Old Aug 2, 2005 | 02:16 PM
What about the package deals you can get like at Hmotors, you know how it comes with the tranny and all the other stuff. What i would is mostly track so it can be modified. I thought i read somewhere a guy did some head work on his K motor and he was putting down like 300whp but i not sure if he had alot of bottom end work to
Old Aug 2, 2005 | 02:29 PM
duckmanEG's Avatar
Sexy Cheese Cake
ya hmotorsonline is a pretty good place. but ur going to still need mounts and a conversion harness unless ur going to do all the rewiring of the harnesses. i think i seen ppl say they have swap k20a2's into there car for around low 5k
Old Aug 2, 2005 | 05:30 PM
So what do you think after you got a package like that for HMotors it would take to run 11's. In a 1900lbs w/driver 93 cx hatch.
Old Aug 2, 2005 | 10:21 PM
edo's Avatar
edo
11.62@119mph
1.79 60' (24.5" M&H slicks @ 5.5psi, spun through 1st)
2100lbs w/driver
2240cc EG
-Ron
Old Aug 3, 2005 | 02:46 AM
Default Re: k-series motor (edo)
thats where i would like to be, what kinda whp you putting down
Old Aug 3, 2005 | 07:40 AM
edo's Avatar
edo
These dynos were done with our first set of cams. We have since switched over to our next step up, but do not have a dynojet chart to go with the dynapack. I like to present both whenever possible. However, if you'd like to see the improvement, I have the dynapack only, isolating the delta from the cam swap/tuning:
-Ron
Old Aug 3, 2005 | 09:22 AM
do you know what all was done on that motor
Old Aug 4, 2005 | 01:04 AM
edo's Avatar
edo
Of course, it's one of my development motors. Look for a full article in the coming months hitting the newsstands. Otherwise, there are many threads here on H-T that chronicle the buildup.
-Ron
Old Aug 4, 2005 | 01:25 AM
MidShipCivic's Avatar
https://honda-tech.com/zerothread?id=1329001
Rasheed1105
Honda Civic (2001 - 2005)
Jan 19, 2019 03:46 AM
b20EGvtec
Aug 22, 2009 02:54 AM
eg6-trans
Dec 27, 2007 05:25 PM
