clutch on a 89 d16a6?
Old Aug 2, 2005 | 08:52 AM
AZTEKEF9's Avatar
Default clutch on a 89 d16a6?
well i'm doing the clutch on an 89 si....wanted to know if i can upgrade the clutch/flywheel combo to a 92-95 civic ex/si combo.....i knoe that if i have a z6 motor and a ef si tranny, i can switch to a 92-95 clutch/flywheel combo....just wanted to know if i can do the same to an 89-91 a6 motor?
Old Aug 2, 2005 | 09:21 AM
HumanResource's Avatar
Default Re: clutch on a 89 d16a6? (AZTEKEF9)
YUP
89^ have 20 spline
it'll work
Old Aug 2, 2005 | 09:39 AM
AZTEKEF9's Avatar
Default Re: clutch on a 89 d16a6? (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">YUP
89^ have 20 spline
it'll work</TD></TR></TABLE>
but the disc is bigger on the 90-91 and the 92-95 is even bigger....so wanted to know if it'll work...the 92-95 combo with the a6 motor?
Old Aug 2, 2005 | 09:47 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 &raquo;</TD></TR><TR><TD CLASS="quote">
but the disc is bigger on the 90-91 and the 92-95 is even bigger....so wanted to know if it'll work...the 92-95 combo with the a6 motor?</TD></TR></TABLE>
The 90+ d series clutches are all the same...The discs are all 212mm.
ACT lists the same disc and pressure plate part numbers for the 90 clutch kit and the 92 clutch kit.
Old Aug 2, 2005 | 10:26 AM
AZTEKEF9's Avatar
Default Re: clutch on a 89 d16a6? (91civic)
so 92-95 clutch combo would work on my 89 motor/tranny?
Old Aug 2, 2005 | 10:28 AM
EP3_05's Avatar
Yes
highrev1987
Feb 15, 2006 06:57 PM
Sik Wit It Hatch
May 29, 2005 08:40 AM
alexsracing
May 19, 2005 02:54 PM
Kyles ej1
Nov 3, 2004 07:02 PM
I Have an STD
Nov 1, 2004 12:03 PM
