Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Crank Angle Sensor for Legend (Type II)
Old Aug 1, 2005 | 11:48 PM
CompanyFlow's Avatar
Default Crank Angle Sensor for Legend (Type II)
Roar. Where can I find one?
Old Aug 2, 2005 | 07:03 AM
Kalokohan's Avatar
New User
Default Re: Crank Angle Sensor for Legend (CompanyFlow)
Your friendly acura dealer should have it.
Old Aug 2, 2005 | 12:25 PM
Default Re: Crank Angle Sensor for Legend (Kalokohan)
Well nevermind then, id rather drive it broken in that case.
Old Aug 2, 2005 | 01:13 PM
Kalokohan's Avatar
New User
Have you checked Ebay? I saw one there. Also, I have one from my old Type I engine. It had 97,XXX when I pulled it out in favor of a Type II. The engine is still together but I have already taken out the timing belt so the crank angle sensor shouldn't be hard to get to. I believe the sensor is the same for both Type I and Type II. Let me know.
Old Aug 5, 2005 | 05:53 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Your dealership should have one, if not they can overnight it to you.
Old Aug 6, 2005 | 12:06 AM
If theyre the same then I have a ton of them. Confirmation on if theyre the same anybody? Im looking at RangerJoe on this one.
Old Aug 6, 2005 | 12:17 PM
Kenso's Avatar
HT White Ops
The sensor is the same for all G2 Legends.
Old Aug 6, 2005 | 04:29 PM
Default Re: Crank Angle Sensor for Legend (Kenso)
YES!
Old Aug 8, 2005 | 05:27 AM
Duane_in_Japan's Avatar
Is this sensor behind the cam gear with 4 wires, if so it can be changes without removing the timing belt. Sorry I do not follow this forum much but I know Hondas just rusty on your terminology, gen 2, I dont try to memorize this stuff but explain it to me and I got it.
Old Aug 9, 2005 | 09:11 AM
Kalokohan's Avatar
New User
Default Re: Crank Angle Sensor for Legend (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Is this sensor behind the cam gear with 4 wires, if so it can be changes without removing the timing belt. Sorry I do not follow this forum much but I know Hondas just rusty on your terminology, gen 2, I dont try to memorize this stuff but explain it to me and I got it.</TD></TR></TABLE>
No, that is the cam sensor, hence it's behind the cam gear. The crank angle sensor is located above the crank(shaped like a "V") and you HAVE to remove the timing belt to remove the sensor.
luder916
Jun 11, 2007 08:07 PM
hondacivicgirlfriend
Apr 27, 2006 01:37 PM
WhippinTheLude
Oct 20, 2004 06:33 AM
B18C1 '96 Coupe
Mar 15, 2003 06:49 AM
