My auto shifter is stuck,...
Old Aug 1, 2005 | 07:48 PM
bobobram's Avatar
Default My auto shifter is stuck,...
I have an 89' accord dx. The problem is when I start the car up and press down on the brakes, my shifter(automatic) will not move. It has a key lock feature where when the car is off you can put a key into a little insert and unlock the shifter column. But when the car is started and the brake is pressed on it should automatically enable the shifter column, right now the only way to use it is to start the car in neutral, not park, it keeps getting stuck in park no matter what I do. Any help is appreciated.
Thanks,
-Kyle
Old Aug 1, 2005 | 11:59 PM
Vanilla Sky's Avatar
blah, i hate those interlocks. i've never had one before, but i just had to post to express my distaste for them.
Old Aug 2, 2005 | 11:33 AM
ScentlessCheese's Avatar
there seems to be an electrical problem,, there should be some kind of switch when u press the brake the switch turns on n releases the lock,, i would look for this switch and the wires and check that they are all working,, check fuses u know jst take a run through.... if u cant fin dit take it to a mechanic...good luck
Old Aug 2, 2005 | 11:35 AM
deserthonda's Avatar
Default Re: My auto shifter is stuck,... (bobobram)
could have a bad brake switch,,,,,,,,,do brake lites work??? bad brake lite fuse???if fuse ok , jump the connector at brake switch see if it works then
Old Aug 2, 2005 | 11:47 AM
honda_kid42's Avatar
also if the idle is set too high it wont shift either...
dyllanfranks
Honda Civic (2006 - 2015)
Oct 30, 2016 10:57 AM
BulldogTJ98
Jul 27, 2008 09:21 AM
standbackimapro
Jan 27, 2006 06:07 AM
puppetmstr80
Aug 26, 2005 11:43 PM
bobobram
Aug 9, 2005 09:25 PM
