SOHC ZC swap gone wrong!!!!
Old Aug 1, 2005 | 07:08 PM
89hbcivicguy's Avatar
Default SOHC ZC swap gone wrong!!!!
Hey guys i just got done swaping out my old d15b2 with a sohc zc as well swapping to mpfi
allsaid and done it started right up and ran fine but clouds of white smoke
so i did a compression test to see if it was the head gasket and results were 150 pounds across the board.....so i automatically thinkintake gasket and replaced it still smoking so i took the manifold back off and there was coolant in the manifold but only in #2 cylinder intake port.....could this be a bad intake? orwhats goin on?
Old Aug 1, 2005 | 07:23 PM
SYN4DRDX's Avatar
Default Re: SOHC ZC swap gone wrong!!!! (89hbcivicguy)
replace the intake manny gasket yet? like a 12$ part worth a shot.......
coolant does run through it on the #4 cyl side.....
BSM_89Si
Jul 28, 2010 10:38 PM
migizzel
Mar 19, 2006 05:24 PM
Gumbey75
Feb 28, 2005 06:17 PM
C-RICKS
Sep 13, 2004 01:17 PM
crxhybrid85
Aug 8, 2004 10:21 AM
