axel Q's for b-series into 90 dx hatch
Old Aug 1, 2005 | 05:53 PM
vtc-gn2's Avatar
Default axel Q's for b-series into 90 dx hatch
so i am getting ready to put in an ls/vtec into my 90 civic hatch. i have the motor and jdm j1 tranny. i was wondering what year axels to use and if i nead to get si hubs or not?
Old Aug 1, 2005 | 05:57 PM
Crx Jimmy's Avatar
Default Re: axel Q's for b-series into 90 dx hatch (vtc-gn2)
90-93 integra axle's for dx you do not need to change spindles but remove the dust ring off back of spindle where axle goes in
Old Aug 1, 2005 | 06:00 PM
Hamstr323's Avatar
Default Re: axel Q's for b-series into 90 dx hatch (Crx Jimmy)
any bseries axels can be used as long as u use the same year half shaft
Old Aug 1, 2005 | 06:08 PM
Malgerus's Avatar
Do you have the Integra Intermediate shaft, or the SiR shaft? The SiR shaft is slightly longer and requires a bit more work to get an axle to work in there.
Old Aug 1, 2005 | 06:10 PM
b18_crx's Avatar
Default Re: axel Q's for b-series into 90 dx hatch (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">Do you have the Integra Intermediate shaft, or the SiR shaft? The SiR shaft is slightly longer and requires a bit more work to get an axle to work in there.</TD></TR></TABLE>
if you use the j1 intermediate shaft with 90-93 axles you will cause premature failure in the passanger side axle...personal experience.........
if its a dx u can use same hubs
Old Aug 1, 2005 | 06:56 PM
Reelizmpro's Avatar
Default Re: axel Q's for b-series into 90 dx hatch (b18_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_crx &raquo;</TD></TR><TR><TD CLASS="quote">
if its a dx u can use same hubs</TD></TR></TABLE>
Interesting that you say this because my CRX has a bad passenger side axle and I have a J1 tranny and probably a J1 intermediate shaft. I've never heard of this problem though and everyone says use 90-93 integra axles. So what axles do I need? I need to do both of them soon.
Old Aug 1, 2005 | 09:04 PM
b18_crx's Avatar
Default Re: axel Q's for b-series into 90 dx hatch (Reelizmpro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reelizmpro &raquo;</TD></TR><TR><TD CLASS="quote">
Interesting that you say this because my CRX has a bad passenger side axle and I have a J1 tranny and probably a J1 intermediate shaft. I've never heard of this problem though and everyone says use 90-93 integra axles. So what axles do I need? I need to do both of them soon. </TD></TR></TABLE>
you use 90-93 axles but you want to use the intermediate shaft from 90-93 usdm integra ys1 or s1........
Old Aug 1, 2005 | 10:33 PM
ef92b's Avatar
you use 90-93 axles but you want to use the intermediate shaft from 90-93 usdm integra ys1 or s1........</TD></TR></TABLE>
check for the "SK7" stamp on the half shaft. i'll post a pic later(showing the sk7 stamp on the half shaft) since i'm goin to receive mine tonight.
Old Aug 1, 2005 | 10:44 PM
Reelizmpro's Avatar
Default Re: axel Q's for b-series into 90 dx hatch (ef92b)
I'm confused though, the J1 only came from the Integra XSi according to what I've read on the net. So why would using 90-93 integra axles be a problem?
Old Aug 1, 2005 | 11:03 PM
CRX7's Avatar
So how does the half shaft which is on the driver's side affect the passenger's side? If you've looked at the axles, the passenger's side axle is inserted directly into the transmission. On the driver's side you insert the axle into the half shaft and then the half shaft is inserted into the transmission.
BTW, I have an LS intermediate shaft and am using 90-93 integra axles on both sides and I'm still having problems with the passenger's side axle. It works with the dust boot removed, but still seems like it's too long. Gives a slight vibration while driving and fails prematurely.
nexgen91
Mar 26, 2006 08:44 AM
89SIR Civic
Jan 16, 2006 03:54 PM
shawn_crx
Jul 27, 2005 03:26 PM
migs
Jul 22, 2004 02:41 PM
CivicEK.PDX
Apr 17, 2003 06:28 PM
